Ok so I can't find anything I like so I'm gonna build my own. I know how big it needs to be and how much port space is needed thats not an issue, but I'd like to know what material would be the best for building it ?
I'm also planning a plexi-glass front with a mirrored interior, has anyone done anything similer that you guys know of ? I figure if I'm gonna do it I may as well make it awesome looking right ?
3/4" mdf
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Ok, cool thanks. Now is that a Home Depot thing or where can I find it at ?
Thank you again.
I've seen at Lowes in 4 x 8 sheets, so i'm pretty sure Home Depot will have it.
Awesome Lowes > Home Depot anyway ! And I can get my plexi-glass there to ! I know what I'm doing this weekend !
Thanks guys!
both places carry it.
home depot sells 2x4 handy panels of it though.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
each place should be able to cut them into the size of panels you need as well. I do it all the time and take the left-over bits as well. way easier to fit in the car that way.
dont forget yur gonna need at a minimum 1/2 plexi but i recomend 5/8 or 3/4. The stuff lowes and home depot carry is gonna be thing and is gonna flex really bad and eventually blow out.
You can special order from depot, either plexi or lexan, not sure aboot lowes
wysiwyg wrote:both places carry it.
x2...thats what I use most of the time (unless I need bigger) it much easier to cut down than a full sheet.
RE Audio
Lash wrote:wysiwyg wrote:both places carry it.
yea, trying to manuever a 4x8 sheet by yourself is a hell of a task, lol.
Most of the boxes i build for people, i usually try to keep the width to 24" so i can use the handy panel, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
So then the 1/4 inch plexi-glass is never gonna cut it. Now I'm not running a ton of power here so do you guys still think the 1/2 inch is ness. ?
1/4" plexi is NOT thick enough.
The larger your window, the thicker it needs to be.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Ok then 1/2 inch it is ! lol ! I need 2, 12" x 12" pannels cause I'm running 2 10's and I want a little room around them.
ya 1/4" is to small lol
heres some pcis of 1 of my old boxes
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
Not bad Mike, I'm doing the reverse where the subs will be mounted in the plexi glass and the back, sides, and top and bottom will be solid.
Thanks guys now I just need to track thie stuff down.
www.professionalplastics.com
Great prices on 3/4" plexi. They will even custom cut it as needed. Check it out. I would highly recomend useing 3/4" so youll never have to worry about it.
AWESOME man thanks! I'll go there now.
Siegel1719 wrote:www.professionalplastics.com
FOUND IT !!! Its not even $30.00 for the 2 pieces I need! Thanks I'll be ordering them tonight!
