I need some opinions. What would be better to have in the rear deck 2way speakers or three way speakers?
____________________________________________________
2002 2.2L -Base Model- (not for long) Black Cavalier
2 Ways. Anything above that is a waste of money.
"Speak the truth, and leave immediately after"
"The urge to save Humanity is almost ALWAYS a false front for the urge to rule"
"He who knoweth things as they are and not as they are said or seem to be, he truly is wise, and is taught of God more than of men."
Bill, 3-way or more is better for sound reproduction. I have Pioneer 6X9 4-ways in mine and the sound is great.
98 Z24
RIP Specks
I always like 3-ways more than 2 ways, unless it's with anouther dude.....
Causa latet vis est notissima
DIY Clear 03+ Headlights
i got the pioneer 5 ways in mine.. it is clear for mids and highs.. dunno bout the bass cause i turned the bass boost off on my amp so its only doing mids and highs, when i dont have the subs in i turn up the bass boost on my amp for the speakers (havent yet cause have not had the need to pull the subs out) hehe
2 ways if you have subs. 3 ways if you dont.
you snooze you lose!
keep working, millions on welfare depend on you!
revvvin87 wrote:2 ways if you have subs. 3 ways if you dont.
Best Time 15.917 at 86.86MPH
Go with the 3 ways Ive got 2 pair of Pioneer 4 ways and they sound great with my sub, they cover alot more range than the 2 way
I think I'm gonna go with the 2-ways. I will have 2 10" subs in the trunk when this is all said and done. The components up front plus the door speakers should help with anything that I miss with the 2-ways.
Thanks for all the input.
Go with the 2 ways and here is why...
Ideally all sound should come from 1 speaker for each stereo channel for best sound reproductions and proper time alignment. Unfortunately we dont have 1 single speaker that can produce 20hz-20khz effeciently on it's own so we have to split the task up into multiple different sized speakers to get the job done even though that isn't the ideal situation.
It depends on how good your ears are as to weather you will be able to tell a difference or not. If you buy good quality speakers then you shouldn't have a problem either way, but the 2-ways should sound better.
I'd say if your gonna get 2-ways, just get a component set. if you dont want to bother with a component set, just get 3-ways or 4-ways
