rear speakers - Audio & Electronics Forum
rear speakers
Saturday, February 18, 2006 4:08 PM
i have a 2001 sunfire coupe and the back speakers vibraite like crazy. so tomorrow im going to take the deck off and see what i can do. is there anything i can put in there to stop them from vibrateing
Re: rear speakers
Saturday, February 18, 2006 4:36 PM
Sound Deadener like Phatmat,Dyanamat, and walmart sells Accumat. Accumats not to bad. but its sold in small quantitys. but you should be able to get enough to do that whole deck
Re: rear speakers
Saturday, February 18, 2006 4:37 PM
sounds good i also looked in the trunk and the speakers are not screws down theres 4 little clips on every corner. i didnt see and screws
Re: rear speakers
Saturday, February 18, 2006 5:14 PM
Cut 3/4" MDF to the shape of the speaker, to replace the plastic piece. It takes no effort whatsoever to drill through the back dash. Use Dynamat on the dash (double layer). Mount speaker, do not use grill on speaker unless rattling is wanted between grill and back dash cover, and replace cover.
Re: rear speakers
Saturday, February 18, 2006 5:20 PM
sounds good will be working on this tomorrow. the only way to get to the back speakers is to take the whole back of the car apart?
Re: rear speakers
Saturday, February 18, 2006 6:13 PM
also can i use a 6 disk cd changer on my stock headunite my subs runing of the stock one right now i dont really want a aftermarket one
Re: rear speakers
Sunday, February 19, 2006 11:51 AM
no you cant use the 6 disc changer and yes you ahve to tear the whole car apart to get to the bakc speakers. and once ou do it alot you become a pro. i kan take it apart in less that 5 minutes
Re: rear speakers
Thursday, February 23, 2006 5:22 PM
do you have to take off that damn seatbelt boat to get the back side panels off. i am having that issue right now and i have everything taken off of the back accept the bolt on the seatbelt harness and that thing is driving me nuts. i have to be doing something retarded. i took the top 3 plasic pieces off and the 2 wing things that are on behind the seat and pulled most of the side panel off but no joy on the seatbelt.
i drive a 2002 Z24
Re: rear speakers
Thursday, February 23, 2006 6:48 PM
i have no clue sorry. can you send a pik of it???
Re: rear speakers
Friday, February 24, 2006 5:13 AM
yeah ill send a picture of everything once i get home from work.
Re: rear speakers
Friday, February 24, 2006 7:16 AM
what i did was take a 1" x 32" piece of angle iron and bolt it to the underside of the deck
i bolted it just behind the tensioner bars and put pieces of wood between the angle iron and the and the deck about 2/3rds of the space of the gap between the iron and the deck and bolted through the would to pull the deck down and create some tension
problem solved
its really like putting on a subframe brace. same idea anyway
Whats up people?
