Well i put my amp and sub in just to kinda see what it sounds like not even with large enough wire and the thing is makign my roof flex alot at the point where it meets the windows..front and back but i am findgn the front window is chirping..is there any way to fix this?? phil
Yeah, its called sound deadening. Sound deadening prevents the panals from doing that.
yah i figured that much......im goignt o asap..just havent decided to get extreme sound deadenign or the stuff in the group purchase yet..im also going o foam the roof and inner sstructure and urethane the roof beams solid..phil
Philly D wrote:yah i figured that much......im goignt o asap..just havent decided to get extreme sound deadenign or the stuff in the group purchase yet..im also going o foam the roof and inner sstructure and urethane the roof beams solid..phil
Im curoius how your going to foam the roof when its not strong enough to hold the weight and you have electrical wiring in there.
Save our Environment, Plant a bush back in texas.
Two layers of fatmat, and it didn't flex with my two kickers when I had them.
yah thats what im doin,..and then runnign urethane along the roof beams to make sure they are tight and sealed..plus the foam isnt goignt o go into the where the wires are..ie the inner structure of the car..look in the 3rd gen forum they talk alot about it and the guy at our stereo shop says they do it all the time....its all good giuys..thanks for the constructive help..phil
Ok..well here is the issue..i do not want to run a second battery.....do i have to or will a upgraded battery be sufficent?phil
Philly D wrote:Ok..well here is the issue..i do not want to run a second battery.....do i have to or will a upgraded battery be sufficent?phil
what does this have to do with your roof flexing?
