Alright well im replacing the speakers in my 96 Z24 and i was curious if anyone knew the colors for the positive and ground wires.. I couldnt really find anything in the search but maybe i didnt search well enough(??) i dont know.. but i was just curious if anyone knew.. Sorry but I dont know any of the colors either.. You can just copy and paste the stuff below and put the color after the =.. thanks..
Driverside 4x6
Positive(+) =
Ground(-) =
Passenger 4x6
Positive(+) =
Ground(-) =
Driverside 6x9
Positive(+) =
Ground(-) =
Passenger 6x9
Positive(+) =
Ground(-) =
Manta, try these.
Left Front 4x6
Positive(+) = Tan
Ground(-) = Gray
Right Front 4x6
Positive(+) = Light Green
Ground(-) = Dark Green
Left Rear 6x9
Positive(+) = Brown
Ground(-) = Yellow
Right Rear 6x9
Positive(+) = Dark Blue
Ground(-) = Light Blue
98 Z24
RIP Specks
Hey thanks, i went out and looked at the wires and the color correspond.. some of teh colors are kinda hard to tell the color but now that u gave me the colors i can see em now. Thanks for the help.. hope to have the new speakers installed tomma. Also thanks for the quick response
Not a problem. Glad I could help ya out.
98 Z24
RIP Specks
Are these the same colors as on a 2002 with the Monsoon Amp? If not, does anyone know what those colors are, and whcih side of the amp is the output. I'm looking to splice from a new amp to the front speakers w/o running all new wires. Thanks.
Gotta keep on livin', L-I-V-I-N
It's all listed in the FAQ
Yep, I found it. Just didn't go down far enough on the page. Thanks! Quick question though. My Z has an amp, but it only had seperate outputs for the rear tweeters. When I put the 4x6's up front, there was only one plug. I found the link to all the wiring harnesses, but could not find one with this exact setup. To bypass the amp, and use my own amp, I will need to tap into the output side of the harness correct? And then, it should be these wires correct?
LF + = Dk Blue
LF - = Lt Blue
RF + = Orange
RF - = Dk Green
I think this is correct, but I want to be positive. I want to be able to save the harness if I ever decide to sell the car. Thanks.
