Is the cig lighter 12v? - Audio & Electronics Forum
Thursday, August 04, 2005 12:32 PM
I oopsed on my multi meter so I cannot check for myslef...
Is the cig lighter 12v? Or does it go 12.5-15 as the rest of the cars power?
I ask cuz I have verious things (neons, radar detecor, CB Radio) that are meant to be plugged into the cig ligher, but I have them hard wired.
You're reading my line-break, you are a loser.
Re: Is the cig lighter 12v?
Thursday, August 04, 2005 1:13 PM
umm its the same as the rest of the car.... whatever power your cars puttin out is in your cig... you have a 12v battery...i doubt your getti n15 volts...14. somethin max...drops down to 12.7 i think at idle or when cars off
Thursday, August 04, 2005 10:15 PM
At high idle I read 14.9 volts.
I jsut wasnt sure if there was a voltage regulator in there, to provid a steady 12 volt (12 volt max) output.
Friday, August 05, 2005 12:50 AM
i have all my stuff (neons, radar detector) hard wired off the cig and it all works fine, if its made for 12v u can hardwire it in, theres no diff btwn hardwiring and pluggin it into the lighter other than tha fact that if its hard then its not goin anywhere, and imo looks much much better
