remote wire porblems - Audio & Electronics Forum
Saturday, July 30, 2005 12:53 PM
I have got 1 remote wire running from my radio and I sodered two amp wires to it one of the remotes goes striate to my 4 channel amp that powers my mids and tweeters, my second wire runs to a toggle switch so I can turn my sub off or on. my problem is I think I blew the toggle switch because of the load. any help, suggestions !
Re: remote wire porblems
Saturday, July 30, 2005 1:41 PM
check for continuity on both sides of the switch. Make sure you get power on both sides before you do anything.
Saturday, July 30, 2005 1:50 PM
use a relay
Saturday, July 30, 2005 3:47 PM
Theres not much current flowing through a remote wire at all... Something like 500 milliamps..
I doubt you burned out a switch with it.
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
Saturday, July 30, 2005 9:50 PM
I too highly doubt you fried a switch. Check to see if you are getting power through the switch.
If all else fails, and you would like to have an on/off switch for your subs, do what I do. Rather then running the "remote" wire from the HU to the amp with a switch inline, jsut put your switch on a 12v source. You can tap off 12 volts anywhere, put your switch, then run that to the remote input on the amp. Thats what I have always used and it works fine.
You're reading my line-break, you are a loser. Lurch <3's the c**k.
Saturday, July 30, 2005 9:58 PM
Machzel08 wrote:use a relay
I will have to agree with this. Use the remote wire as the trigger for the relay, and run the fused 12v from the relay to the amp.
Sunday, July 31, 2005 8:03 AM
I fixed the problem I found a nice 12v source ran that to the toggle but lol my audiodaun sub amp is in protect mode and wont work so now I have a new set of problems thanks for the help guys.
