OK I used to just put on a simple ground loop isolator in line with the RCAs and it would go away. Now that barely helps, I've tried different RCA wires still having the problem, I've tried using capacitor noise filters on the power lines still doesnt help, I'm really starting to think maybe the deck itself is bad
sounds like it try this. take wire and ground the metal tips of your rcas. see if that takes it away. you can do it at both ends but at the amp is prolly easier.
The isolator is just a band-aid to cover up the problem. Even if your ground looks good, move it to a different location and you will most likely see a difference. If you have more than one amp, ground them with the same screw/bolt. If you are running your amp turn on lead using that moled wire between the 2 RCA's that some company's make, don't use it. I have eliminated noise before just by changing that. Good luck.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
i have the head unit grounded to 3 different places and the amps share a common ground, I even had a ground running from the head unit to the amp, i cant ground anything any more than it already is
remove your negative bat cable, clean it and reconnect it, loosen your alt and move it some, then retighten it. if that doesn't help, try running a ground wire (you can do a temp wire and see if it helps) and ground your radio right to your bat.
Causa latet vis est notissima
DIY Clear 03+ Headlights
Try using factory grounds for the amps.
<img src="http://www.webgraffiti.it/gif/smile12/smile197.gif"></img>
first you need to isolate what is causing the noise.
do you have any speakers running off the deck? is there noise through them? are their noise through ALL the amped speakers?
figure out what's causing it before trying anything and everything.
a few times in my car it's been the wiring on the stereo harness in the dash. cramming all the wires back there and the power wire got tangled with signal wires. i slid the radio out while it was on and the noise went away.TRY THAT!
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
battery term is brand new
Ive thought about grounding right to the battery i need to find some spare cable
I dont run any speakers off the deck they are all off the amps, off the deck there is no noise though, noise is there no matter how much i jiggle the cables
if you only get it in the amp, you can pretty much ignore your stereo connections. I'd hook the RCA's to the amp up to something with some RCA in's and see if you still hear it. if not you know it's in the amp. ground the amp to a different part of your car, turn the gain down some... replace your amp... just listing random crap I'd try
Your RCA's are on a different side of the car then your power wire right?
yea rcas are run up opposite side of the car, gains are down , its not the amp yea the grounds on the head unit are all at the same time
