ebrake light on?? - Audio & Electronics Forum
ebrake light on??
Thursday, June 02, 2005 5:15 PM
ok the problem is with my 95 sunfire. My ebrake light stays on all the time! My driving lights work like they are suposed to ....they come on when the ebrake is off and go off when it is put on. so i know the ebrke switch is working..but for some reason i cant get the light to come off...any clues anyone?!! phil
Re: ebrake light on??
Thursday, June 02, 2005 7:48 PM
http://www.j-body.org/forums/read.php?f=11&i=86217&t=86217
Maybe it is like what we are having with my girls car. Might check that. I also asked some of the tech's up at work(Dealership) said that sometimes water gets in there and just to unplug the abs harness off the hub to see if there is any water in there.
Thursday, June 02, 2005 7:51 PM
no it still works and everything ..and its my e brake...phil
Saturday, June 04, 2005 5:06 PM
nobody????!
Sunday, June 05, 2005 7:41 AM
Did you check your brake fluid level?
<img src="http://img78.photobucket.com/albums/v290/americonium/Heavy_weight.jpg ">
Sunday, June 05, 2005 7:44 AM
yes i keep it topped up....now everything did work fine till the day i chenged my interior. I took the entire interior out including the plastic support dash and from that day on it hasnt worked...but it just seems odd since the daytime lights still work like they are suposed to..maybe i should get another ebrake setup???phil
Sunday, June 05, 2005 10:17 AM
Maybe you left the switch unplugged.
Sunday, June 05, 2005 12:05 PM
nope i took it apart and checked it.....also the daytime lights still work with the ebrake switch like they are supposed to..phil
Sunday, June 05, 2005 5:40 PM
Ah, I see.... Could there be something wrong with the abs? I'm just throwing darts now...
Sunday, June 05, 2005 5:42 PM
The abs has been disconected since i have owned the car...there wa a problem with it not working.i belive the controller is shot so we took the fuse out? or relay im not sure but everything has worked after that was done..the time it stopped working was when i changed the interior..its a odd one i know..thats why im stumped..phil
