Dead yellow wire for radio - Audio & Electronics Forum
Thursday, June 02, 2005 4:24 AM
My radio quit working yesterday, so I took everything apart, and check connections. My yellow wire from the wiring harness is dead. The red one has juice. I checked the fuse in the fusebox, even replaced it, but I still can't get power to it. Any suggestions?
Beat it like it owes you money
Re: Dead yellow wire for radio
Thursday, June 02, 2005 4:40 AM
What fuse are you running it to?
-Chris
Thursday, June 02, 2005 6:05 AM
10 amp fuse.
Thursday, June 02, 2005 8:39 AM
The yellow wire is the constant battery source....
Worse comes to worse, just wire it up to a new source.
<img src=http://www.consumptionjunction.com/i/default03.gif>
Thursday, June 02, 2005 11:30 AM
That's what I was planning on doing, I didn't know if that was run off the fuse box, or if there was a fuse for that.
Thursday, June 02, 2005 1:51 PM
If you're running it to the fuse box, you should wire it to something that has constant power, like the accessory fuse.
-Chris
Friday, June 03, 2005 5:00 AM
From the fuse box the "red" wire that's switched is run to the fuse box. It's the stock wiring for the radio. I was going to put an inline fuse for my "yellow" constant wire and run it to the battery.
