Wet kit: Fuel line tap? - Nitrous Oxide Forum
Thursday, October 11, 2007 9:51 PM
I was thinking about putting a wet kit on my 97 Z24 and was just wondering if there was a place on the end of the fuel line I could tap into for the fuel solenoid. I know on lsx powered cars they have it and I was just wondering if my car had it and its raining so i dont want to go outside to look. Also If i do spray it would it be safe to run a 125 wet shot?
97 Cavy 2.2
Re: Wet kit: Fuel line tap?
Thursday, October 11, 2007 9:52 PM
I mean at the end of the fuel rail not fuel line...
97 Cavy 2.2
Thursday, October 11, 2007 11:23 PM
Nope,unfortunately the 2.4 guys don't have a Schrader valve like the Eco's do so you can just tap into your fuel line with a fuel tee and run it to your fuel solenoid.And even if your motor is built I wouldnt recomend a 125 shot,stock 50-75max,100,built motor with timing retard among other things,Faq and stickies at the top of the page will help you.
Sunday, October 14, 2007 8:58 PM
So where is the best place to tap the fuel line on a 2.4? FAQs dont really give too much info on tapping the line
97 Cavy 2.2
Monday, October 15, 2007 9:56 AM
Anywhere you want where there is a rubber part of the fuel line.
Monday, October 15, 2007 9:09 PM
Hmmm so would something like this work to tap it http://www.harrisspeedworks.com/shop/product.php?productid=16608&cat=347&page=1 im just trying to figure out the best way to do it without it leaking..
97 Cavy 2.2
Tuesday, October 16, 2007 6:35 AM
Basically you want something similar to that, but with barbed ends on (2) of the sides for the rubber line and (1) threaded side to run to the solenoid.
Thursday, October 18, 2007 8:19 AM
Any idea where to get one? I looked at lowes and homedepot and didnt really see any. I found some tees with the bared on all 3 so i got those but now i need a way to hook it up to the an fitting
97 Cavy 2.2
Thursday, October 18, 2007 8:38 AM
Typical stores won't have that, no. You'll need to go to a place that does specialty fittings and such. If you absolutely can't find it near you and would like to order it, try my place. Just make sure you had all the dims handy when you call. I'm sure they'll ship if you're in a bind.
Shako Incorporated, 6191 E Molloy Rd, East Syracuse, NY 13057
(315) 437-1294
http://www.shakoinc.com/
Sunday, October 21, 2007 5:37 PM
ok i think i got the T figured out.. The stock fuel line is 3/8th right? Now i just need to find an adapter to get from the fuel line to the solenoid or atleast to the braided fuel line..
97 Cavy 2.2
Monday, October 22, 2007 9:19 AM
Here is my setup,granted not the best or nicest looking but works without leaks,the filter can be found cheap at Autozone and I have since replaced the rubber fuel line from the tee to the filter with braided line.
Monday, October 22, 2007 9:36 AM
So what is that piece that goes from the rubber line to the solenoid? Thats the only problem i have left with my setup
97 Cavy 2.2
Monday, October 22, 2007 10:45 AM
A small fuel filter,screws right into the solenoid and only costs a couple bucks.
Monday, October 22, 2007 6:33 PM
Thats awesome, thats alot....
97 Cavy 2.2
