interested in seeing some times you guys run on the spray, post your car/motor and what size shot your running , mods and what your 1/4 time is?..
I couldn't tell you the 1/4 mile time because i spun my #1 rod bearing on the way to the track this fall to see what it is capible of. I have raced a friends Fwd turbo dsm he has run consistant mid 14's and i can hang with him or even inch by him once in a while.
01 ohv manual
header
2.25 exhaust
62mm TB
wai
j tuners pullies
75 wet shot
When i am done with my engine build i will deffinatlly go to the track asap to see what i run on a 100 progressive and build ohv.
jeff
Its in the FAQ
I'll be hitting the track when it warms up with these mods
Zex Wet Kit 75 shot
Zex Purge
Autolite 103's
RK sport Upper motor mount
RK sport 4-2-1 header
Fidanza Short throw
RK sport Lower Motor mount
2.25" Catback exhuast
Fidanza 7.5 lb flywheel
Spec Stage III clutch
Bomz warm air intake
This will be on an ecotec 5 sp Base cavy
2.4 5 speed
RK upper and lower engine mounts
AEM Intake
RK dual Magniflow (cat-back)
75 shot NOS
13.909@100.71
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Leave it to Brian to be one of the first people to toot his own horn about how fast his car is...what's your car running now with those high performance car jacks under it?
Last place you'd expect to hear me from, huh B-Lo. Tell the wife I said hi.
SGT Crucial
B Co. 10th CSH
Task Force South
Team GREEN
Suspension Division - "Handling Before Horsepower"
Making the turns since 1999
1998 EK Civic Hatch - Yes, it's a Honda.
2004 Cavalier Ecotec 5-speed
RKSport intake
Cams
Ported Intake manifold
Port matched head
Prothane upper transmision mount
Prothane lower transmision mount
RKSport upper motor mount
RKSport lower motor mount
RKSport spark springs
RKSport light weight underdrive pulley
Weapon-R 4-2-1 Header
High flow cat
2.25"Custom catback
2.25" exhaust cutout right at the end of header
QTP Electronic valve for cutout
RSM 62 MM Throttle body
Autolite #103
Nitrous Express Import EFI wet kit (100 shot)
B&M short throw shifter
strut mounts for a '99 cavalier
RKSport Prostreet coilover assemblies
Vibrant front strut tower brace
Vibrant rear strut tower brace
Custom Subframe Brace
Prothane control arm bushings
15" wheels
Drag radials
13.08 @ 106 without a full run, I had to let off way early (as in before the end of the track) to avoid hitting the limiter on spray. Prolly could have squeezed maybe another 1/2 second of it with the limiter disabled
^^^ oh yeah that was on 104? octane
See sig for times and reg for mods.
see my reg for mods and times
![](http://i134.photobucket.com/albums/q109/99redz24/camarosig.jpg)
look @ their mods/times for what i'd like...
