pros and cons . one piece tension - Third Generation Forum
Tuesday, December 22, 2009 4:45 PM
i have a 99 z24 .. is there any advantage to using the older style one piece tensioner over the newer style two piece
Re: pros and cons . one piece tension
Tuesday, December 22, 2009 6:48 PM
bump
Tuesday, December 22, 2009 9:06 PM
bump
1999 2.4L w/ nitrous
Wednesday, December 23, 2009 3:49 PM
Yes, one piece is better!
Tuesday, December 29, 2009 5:34 PM
bump
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Wednesday, December 30, 2009 7:30 AM
Most people can't figure out the two-piece ones.. if you can push the middle in enough to make it pop, it usually works just fine.
I've used both... never had any problems. As long as you set it, and it pops out.... you're good to go.
Thursday, December 31, 2009 10:30 AM
I have only ever come across one style of tensioner in the 2.4 and I assume its the 2 piece. Have never had any issues with it at all.
Friday, January 01, 2010 8:39 PM
You can get the 1 piece by asking for a 96 2.4. I have had bad luck with the 2 piece ones. We had 6 of them, 3 new 3 used. All but one did not work. If I'm working on a 2.4 and delaing with the timing chain then I will have to have a 1 piece or I wonlt work on it. Too many times getting screwed with the 2 piece.
