just wanted to give you all an up date on my project, in December I swapped in a 3400 in my 96 cavalier using a Megasquirt(thanks for you ms guys that sent me a starting tune) was going to turbo it using the GT3767ts that I have from my buddies 600hp Honda, but I don't have the money to buy the waistgate, innercooler and other expensive crap to finish it.....so I cut the lid off of a 3500 plenum( I know, i know don't hate me) and fabbed a plate that a 94 Bonniville supercharger (m62 i think) bolts up to and also made an idler that rides above the powersteering to hold tension on the blower............the only bad thing that I wish I could remidy is that the blower is gonna stick out the hood( but hay it worked for the muscle car guys..lol). I have tempates for every piece that I have made, should be running in about 1-2 weeks( in switching to e85 first) ............not shure how to up load pics anyone know how??????
nice bro, i NEED to megasquirt my 3100 because the grandam pcm just doesn't run right.
Best would be to use a t-bird M90 and remote mount it somewhere. Where to mount it is the hard part.
Turbo pretty much sounds like king.
www.gmscf.com
yah I'm worried about the boost not being enough cuz the Bonniville has a 8" crank puly and my 3400 has a 6"..... does any body know if the front drive off of a m62 will bolt up on a newer m90????? I'm trying to find a core, because this blower has a very small puly compaired to the factory newer ones like the GTP's... but either way it might tide me over untiIl I get the scratch for the turbo parts. I did some measuring and I think I can squezze the gt37 behind the engine (above the pasenger side axle) so Im going to start making headers once this contraption is on and making noise. then well durability test the factory head gaskets....LOL
What about getting a modular pulley set-up for the M90? Then you wan swap pulleys instead of snouts.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
yah im thinkn I need a m90,, does any one know if the front bolts on the same? the newer ones have to long of a drive nose on them for the intake that I made. I just finnishedd welding the plenum together man 3/8 plate aluminum takes a lot of heat to weld. uhhh! but its done. now I jsut need to figure out if the m90 will swap snouts? anybody have any gtp friends. LOL.................................ps the bagged cav looks sick!
charles Geibe wrote:yah I'm worried about the boost not being enough cuz the Bonniville has a 8" crank puly and my 3400 has a 6"..... does any body know if the front drive off of a m62 will bolt up on a newer m90????? I'm trying to find a core, because this blower has a very small puly compaired to the factory newer ones like the GTP's... but either way it might tide me over untiIl I get the scratch for the turbo parts. I did some measuring and I think I can squezze the gt37 behind the engine (above the pasenger side axle) so Im going to start making headers once this contraption is on and making noise. then well durability test the factory head gaskets....LOL
M90 = 90ci of air in 1 rotation
3400 = 207ci of air every 2 rotations
207 / 2 = 103.5 per rotation
Stock GTP pulley I belive is 3.8". With a 6" crank pulley that's a 1.57 ratio.
90 * 1.57 = 141.3ci per rotation.
141.3 / 103.5 = 1.365
14.7 * 1.365 = 20.0655
20.0655 - 14.7 = 5.3655 psi of boost on an M90 with stock 3400 crank and stock GTP s/c pulley.
Not a lot, but a decent amount to start out with to get yourself tuned on.
www.gmscf.com
I wonder how a 3400 would take an M112.
I'm also actually curious if anyone has upgraded a 3800 from the 90 to the 112. It would obviously take some fab, but it wouldn't be doo bad of a project.
Edited 1 time(s). Last edited Friday, July 17, 2009 6:34 AM
zz performance makes a plate to do it i looked into it but for the cost of everything i could turbo my car
Quiklilcav wrote:I wonder how a 3400 would take an M112.
Probably not well. A 2-1 ratio for a 112ci blower on that 3400 would likely be over 15psi. That's sure to blow the head gaskets at least, if not other parts and pieces of things.
www.gmscf.com
