done the search no luck....
engine 2.2 non eco
problem is that i spend the weekend replaceing my head gasket and tuning my the engine and only problem i ran into was the chrome fuel line that connects to the fuel rail next to the power steering box, well it doesn't seem to want to go in all the way or something, i replaced the o rings on it and inserted the rail into its connections tightened it down then during the first start to check for leaks sure enough it was spraying fuel, removed the line checked for depree in the hole nothing, check the line for issues, none, no cracks no bends no breaks, ... no idea
so i turn to my fellow 2.2 and j body lovers for suggestions
Thanks in advance
check and make sure there is not an o ring stuck inside the fitting you are putting the line into.
![](http://i37.photobucket.com/albums/e69/wjz24/notforsalesig.jpg)
i did check for depree and such in the fitting and couldn't see or feel anything but can't hurt to check again...any other thoughts
