Hi I am new to the forum. I have heard good things. I stuck with neons most my life and I got a cavy for a school car. Less then a month and I have had the worse problems. Today I slammed second gear and it didnt go in. I put it into 3rd and it went in. After that the shifter was mostly free play. I put it into 5th because it was a long drive home. I checked it out. When you push the shifter forward from 4th to 3rd (when the tranny is in 4th) it will change the gear to neutral and 3rd. It will move SIDE TO SIDE in neutral. But when its in the up position 1st 3nd or 5 it wont go anywhere the shifter has play back anf forward but not side to side. It wont pull it out of gear. So if you get what I am saying and how it works the up and down shift linkage will only pull the shift arm on the tranny. It wont push on it. I know the side to side linkage is fine. I assume its the shift linkage? I dont get it. Its still works one way but just not the other. Is there any kind of pins or adjusters on the linkage that may have broke and giving it free play when it the 1st 3rd and 5th. Anyone have a link for a "hot to" change the @!#$ linkage. Oh yea. I figure from that you know its a 5 speed manual transmission and a 97 cavaluer z24 2.4 dohc.
Sorry to revive an old thread but the exact same thing happened to my 98 Z24 on Fri. I haven't looked at it yet. Did you ever get yours resolved?
don't slam it into second might be a good start
thats like my dash make this squeaking noise, when does it do it??? when i hit it, WELL DON'T HIT IT
JBO since July 30, 2001
Thanks for the ideas, I haven't even bothered to dig into it yet. Maybe this weekend.
After rereading Quiklilcav's post it sounds like I was looking at the wrong side
Guess I'll take some more pics tonight.
Well still no dice, I should be able to shift the tranny by moving the assembly (in the pic) on top of the tranny right?
I'm starting to think the 3rd gear synchro is fried
New tranny time or should I rebuild it?
Well finally got the car in the shop for a diagnosis.
Bent shifter fork (3rd gear). Shop quote:
$3600 for GM rebuilt tranny
OR
$2900 for salvage tranny.
I can get a 40k mile salvage tranny for $750.
What would you do?
lol the car isnt even worth that much. get a salvage tranny for 750 and get a few org members to help you out. im sure someone around your way can help out for little to no cost.
I know, it was more of a rhetorical question. Guess I left out the
I think I'm gonna do the NVG swap.
Actually I had the same problem today, but luckily for me I just broke the shifter cable for the odd gears(1, 3, 5)
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
