i read somewhere on here last night and i can't remember which one it was in now, someone posted that they had gotten a ticket for doing 137 in a 70 and something to the effect of your lucky the cop pulled in behind you and not in front of you. 1. our speedometers don;t even go to 137 they only go to 110, 2 if he went past like 106 or 107 the governor would kick in the engine would shut itself off and the cop cruiser would be able to catch up to him in nothing flat . I just found the entire post interesting doesn;'t make sense to me how he could even get the car to 137 unless he disabled the governor.
The motor doesn't technically "shut off" at 107... but yes the goveror has to be eliminated one way or another to excede 107. If my car makes enough power, I could do 137. But with HPTuners out now, it is even easier for people to do this.
"Youth in Asia"...I don't see anything wrong with that.
ok???
oh ok my bad Brian i thought i had seen somewhere that if you exceed 107 or 108 the engine would cut out maybe i'm mistaken.
Basically, it works like this:
Embedded within the code of the ECM is the control for the speed limiter as set by GM.
What this bit of code does is based on an input from the vehicle speed sensor, will shut off the fuel injectors once the vehicle reaches a ground speed of 106 MPH. Once speed is reduced to 104, the control to the injectors is turned back on, allowing the operator of the vehicle to reduce to a safe speed.
This safeguard was put in place due to the overall design of the vehicle. The brakes, suspension and tires were not designed for speeds in excess of 100 MPH. Given that there is a variance allowed by the DOT and NHTSA for speedometer readings, it can be inferred that GM has placed this limitation a small amount higher to compensate.
Without altering the code contained within the ECM or by disabling the input by other means, it is impossible to achieve speeds over the limiter.
thanks for the info Kardain much appreciated.
did you ever think that mabey the guy was in canada, and that 137 KM/H in a 70 zone??? 137km/h is about 85mph.
yeah Kardain that;s the one.
i dont think his speed was even disclosed in the post, yet.
I'm back from the dead.
Currently Driving: RSX Type-S.
My Cavalier Burnt up :-(
Not ground speed... rather its
indicatedspeed.
Changing tire size to larger or smaller diameter will change actual speed the cut-off happens, but it will still be indicated as 108mph.
sig not found
Wil Ketchin wrote:i dont think his speed was even disclosed in the post, yet.
not yet, but I'm waiting. curious to see what it is.
Not ground speed... rather its indicatedspeed.
thanks for pointing that out.
When I wrote that it was under the assumption the car is in stock trim, stock tires, no variance in the speedo...
there actually is a free way to disable the top end governer, i did it on my 98 z24. its a manual...
^^ and also A BIG NO NO to mention on this forum.
x2
I did it on my second gen (lasted about 5 mins before I put it back.... thats to fast for those cars) so I know what he is talking about.... but thats one of the top 2 things not to talk about on this site anymore...
Speed limiter removal or street racing = locked thread.
for the most part anymore. (just to let the newbies know)
Weebel wrote:Quote:
x2
Speed limiter removal or street racing = DELETED thread.
fixed
^^ they've been locked before as well, just all depends on what's been mentioned in the threads...
Most of the time though, they just get moved to the "Moderators" forum
I've done it in mine too, but like the guy above said, quickly went back to stock. The car is def. not meant for speeds over 173km/h, or 107mph.
car is barely made for 107. my Z24 used to make me white knuckle at 85ish.
GO PATS!!!
yeah mine is back to normally again, decided i dont need to go that fast i proved my point with it so now its back on plus it really eats a lot of gas to top it out but like you guys said forget it on here
Kardain wrote:Basically, it works like this:
its not just the fuel injectors, trust me on this one
Ive disabled the fuel cut before, and the bitch still bucked down. that bitched pulled timing faster then a fat chick goin for the last burger.
boobs now with Riboflabin"
Only reason it dont work on my car is because the stock PCM is no longer in control of the fuel or ignition systems. Only the speedometer.
But I still dont drive it that fast, unless it would happen to do so on a pass down the track.
^^^Pretty much how I feel...
Whenever I get around to tuning my car... Just because the thing will be capable of doing 140mph... doesn't mean I'm going to drive it that fast on the street (the track might be a different story)
There is a certain burdon of personal responsibility that people should follow... but since most people dont... thats why are cars are governed. If your responsible it doesn't need to be there... but more oftan than not... that isn't the case... wich is kinda sad.. and annoying when you think about it.
If you can tell your going to fast..... slow the hell down.... the computer shouldn't have to do it for you.
