A little while ago my check engine, coolent level, battery lights came on. Basically all the idoit lights lit up while I was driving. Also the odmeter was flashing "error"
![](/global/images/emoticons/al.gif)
I stopped and turned off the car and it did the same thing again. My car seemed to be running okay. I turned off the engine and started it 4 times. On the fourth try I waited about 5 mins before I restarted the car and things went back to normal. Has any one else seen this happen?? let me know, Thanks
Driving a busted-up 03 cavy (damn black ice 3yrs ago!!)
Got a front bumper last year, just too lazy to paint it, and put it on
My (Original)90 Z24 is now being retired
Way too much rust
Maybe it will become a V8 or something very wrong (4x4)
Picked up another 90 z24 from the west coast no rust!
![](/global/images/emoticons/jbo.gif)
But a rod bearing is spun. I got a motor, just need time!
Man do I ever miss my 3.1 V6
If you try to scan the codes, what happens? Will the scan tool even make a connection with the ECU?
on the 03 cav? do you have the stock cd player?? definitely something in the bcm. mine did that when i connected the wrong wire in my radio harness and everything was fine unless i turned on the radio and it threw power into one of the bcm wires and my whole gauge cluster went wacky.
