headlight issues. - Third Generation Forum
headlight issues.
Monday, August 22, 2005 8:45 AM
one of the bolts that holds my headlight down is totally stripped. looking for an easy solution. just get a bigger bolt? or get it re-threaded?
Re: headlight issues.
Monday, August 22, 2005 8:53 AM
should be able to pick one up at a dealer or hardware store
Monday, August 22, 2005 11:58 AM
all my bolts are worn out. They sit in the holes. Whatever..........
Monday, August 22, 2005 2:02 PM
Do what i did, take the bolt that is supposed to hold in your headlights to the hardware store and find a nut that will screw in the end of the bolt. Then put the bolt back into the headlight were it is supposed to go, and then screw the nut on underneath the headlight. I did this for the inside bolts of my headlights. I'm not sure what ones you need it for.That is what i did. A simple solution that will cost you all but 25 cents. Hope I helped
<imgsrc="http://www.geocities.com/juicez99cav/cavy_sig_3.jpg">
I am what I am and it is what it is.
I am the 2nd most untrusted person in the world next to a lawyer,welcome to our dealership, may I help you?
Monday, August 22, 2005 2:14 PM
i wrapped my stripped bolt with electrical tape and it holds fine... ghetto fix, my friend told me that one, both his headlights were like that on his cavy......
Now Blazing: Northern Lights
Tuesday, August 30, 2005 7:32 AM
mine did the same thing i just used a bigger bolt after i threaded it for it
Tuesday, August 30, 2005 5:08 PM
gms threads are so weak, i guess the relly dont like us taking anything apart
i got a sig warning
boosted cavfire
Tuesday, August 30, 2005 6:35 PM
Michael Story wrote:all my bolts are worn out. They sit in the holes. Whatever..........
-Www.IznTrbl.Com-
Wednesday, August 31, 2005 8:04 AM
Helicoil kit or some of those large clips with the nut attached should work as well.
