End Link Part Number - Suspension and Brake Forum
Wednesday, November 09, 2005 11:41 AM
I saw in a previous post that Energy Suspension poly sway end link bushings part number was 9.8105R. Is this correct for the front??? These are the last pieces I need to my front end. I have found this part number at Autozone and Advance even though they aren't for cavaliers. If anyone knows somewhere else to buy or the right part number holler.
"If you aren't shifting, then you certainly aren't driving!"
Re: End Link Part Number
Wednesday, November 09, 2005 2:20 PM
Thats a universal set with just the bushings (no links), since they don't have a specific 95+ set. If you want the link also, you'll need to measure up the factory link and order the correct length. All this info is available on the Energy Suspension website.
Wednesday, November 09, 2005 2:30 PM
they make endlinks for blazers and im 90% sure the 4x4 blazers had the same endlink we have. check part numbers on the regular endlinks, then if they are the same, get the poly ones for the blazer. i just took the bushings and put them on the standard endlink washers and spacers. If i remember right, energy suspension doesnt make an endlink in our size, our size is either too small or too large.
