line-lock on FWD - Suspension and Brake Forum
line-lock on FWD
Thursday, November 03, 2005 9:43 AM
I have looked but haven't found out much on this topic. I use a line-lock on my RWD towncar but are they used/effective on FWD cars for launches/burn outs?
Causa latet vis est notissima
DIY Clear 03+ Headlights
Re: line-lock on FWD
Thursday, November 03, 2005 10:53 AM
I don't see how it could work real well because I can drag my rear tires with the e brake set.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Thursday, November 03, 2005 10:55 AM
It's called an e-brake.
You need a line-lock on a RWD car because there's no method of braking just the front wheels. No point on a FWD car.
As mentioned though, you'll just end up dragging the back wheels along so be careful not to flat-spot them.
Thursday, November 03, 2005 8:31 PM
Yeah. You'll just drag the tires. Doesn't work cause the drive tires have way more weight over them than the "stopping" tires.
Sunday, November 06, 2005 12:36 PM
i thought about line locks that lock the front.....it makes sense, rear wheel drive launches you lock the front if you have an auto so you can brake tq.
Therefore if u did it in the front brakes with fwd you could brake tq your auto or use it to keep from drifting out of stage...
2007 GM Tuner Bash...HELL YEA
PA,MD,NJ,DE,NY and all states north caravan
Sunday, November 06, 2005 2:00 PM
^^ Yeah but the noral brake works just fine for that. Why would you add complexity when what you have works??
Sunday, November 06, 2005 5:32 PM
Yeah i added rear line locks to my rear disk conversion thinking maybe the hydralics woudl hold better than just pulling up the ebrake handle and well it the front tires are wet first you can get a nice burnout going but in the dry even with a hirh RPM clutch dump it just ends up dragging the rear tires, which is bad.
Heres a few pics of my setup
Like i said if you go thru the waterbox at the track they do there job, but not as effective on the street.
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
That pretty much says it all.
Support the site that supports your habit, Go Premium.
Tuesday, November 08, 2005 10:36 AM
thanks for the replies.. so no line lock :-) got cha
