I dont think i can afford a full set of yellows...but i have the Koni reds in the rear,...and they are still good but the front blew...
what do u all think i should go for? More koni reds in the front? Should i mix the front with 2 yellows? or buy a full set of AGX?
i am riding on Sportlines...
SPONSORED BY: CAVALIER EXTREME
Mixing and matching the front and back is fine. Left to right is a big no no.
Whatever floats your boat, if you like the reds, get two more. Like the AGX, get them for the front. Want to get rid of the reds, put AGX all around.
Depends also what springs you go with. Anything over a 1.5 inch drop i would not use the AGX. We have both avaliable, let us know if you need a set.
-Aaron
www.TurboTechRacing.com
i am using the sportlines...
whats ur prices on front yellows?
C.T.S wrote:Mixing and matching the front and back is fine. Left to right is a big no no.
Well, so long as you know what you're doing. If the front and back is too different you can definitely change the handling of the car in wierd ways. But since we're talking about Koni Reds, and AGX's, they're basically the same strut, so you're right.
im not gonna mix AGX with reds..
if anything id mix red's with yellows...yellows up front...
keep in mind though, the yellows are supposed to be stiffer than the reds...
i jus want something in the front that rides good...
Since you have sportslines you have two choices: Red or Yellow.
With a bit of attention either will be just as good as the other (unless you want to adjust them after their on the car).
