hey there gang just got my yellows and GC coils installed. i am going to put about 500-750 miles on them before i mess aroudn with adjusting height or stiffness of the struts. just a real simple question that i couldnt find through a search. can you over adjust the struts, i mean when you go to stiffen or loosen them with the white plastic knob can you over crank or does it stop when they are at the tightest setting and the softest setting i just dont wanna screw the struts up. thanks guys.
'spit chew hits soldiers boot'
"thats a real nasty habit you got there"
"this stuff will make you a sexual tyransaur just like me"
jesse the body ventura in Predator
If I knew off hand I'd let you know. Read the directions it should tell you. I know the Dspecs I helped install had a little blurb on going to far one way.
well the directions only have pictures nothing written so i was confused.
They do stop, you can only twist that little tab so far then it stops. It stops when its the stiffest and softest so no worries man.
I guess if you gorilla arm it, you could technically break the stuff on the inside, but it looks like the plastic adjuster tools are set up that they will break before you can twist that hard, so yeah, I wouldn't worry about it.
If you want to keep track, there is a total of 2 revolutions (720 degrees) of adjustment from full soft to full hard.
Sleeper style, they don't see it coming that way.
great thanks for the replies i was working all weekend yeah before i messed with it i wanted to make sure that i didnt over crank or under crank it. and blow the money i spent on the struts and install
where did u get them from i want some to go with my goldlines i live in Canada and noone has a listing
Nick
ordered my through the gp on the group purchase forum about a year and a half ago
