thats right front pass side sit about 1 inch higher than the 3 other corner
why ?
my install is perfect im sure ...
___________________________________________________________
go back and double check that the spring is on right. also if your not on level ground it makes a big difference
[quote=ßãggéÐÇåv98 (Ûñqùðtäߣè Øñé)]go back and double check that the spring is on right.
lol you have the same effect has mine....
I was on Eibach Pro-kit and Koni Yellow. Everything is normal due to the Ecotec engine been less weighted then the others.
All I did is change to Goldline and now my problem is solved. Only the front sits a tad higher. that means not even 0.1".
My Car Specs
Club J-Body Montreal Forums
i've heard of 1/4-1/2", but not a full 1".
achete toi autre chose pi vend moi tes sportline !(tout dependant du prix)
ben jpensais a mettre des ground control cet hiver chez pas mas cheker ca en fds
