I was wondering if you guys have had any problems with your exhaust system scraping or resting on the ground when the bags are fully deflated, Or does the system not allow the car to sit that low. Any info would be appreciated. Thanks.
When totally laid out mine sets on the rear axle and has burned through the cover on the e-brake. but the exhaust itself is about 1/2 to 1 inch from ground.
Ive have custom cat back and I asked them to make sure to tuck it up as high as possible. I still have scrapes along the whole thing from GOd knows what but it dosnt touch when layed out on flat ground.
BUt I can leave some really neat burn marks in people grass. You can see from the downpipe most of the way back. SOmetimes even the muffler is grass is high enough.
I am all that is man
had my exhaust rebent over the axle so it was WELL out of the way
melted a bit of my brake cover previously but now no problems...my cat does lay on the ground when im layed out tho
Phil Thacker
JCO North President
since i have the drift kit, i cant deflat all the way. only to about 15-20 psi. when im that low im about an inch from the muffler touching the ground. i assume if i let it all the way out, id probably just touch the ground w/ the muffler
Some pics of mine
<a href="http://www.imageshack.us"><img src="http://img229.exs.cx/img229/2319/pict07790ue.jpg" border="0" width="640" alt="Image Hosted by ImageShack.us" /></a>
<a href="http://www.imageshack.us"><img src="http://img230.exs.cx/img230/2655/pict07867vk.jpg" border="0" width="640" alt="Image Hosted by ImageShack.us" /></a>
my cat and one of the rear hangers touch the gournd with mine. I guess I had better check my ebrake cable then too.
Brisk and ESB, both your cars are super cool. Thanks for the info and pics. Now I know what I have to look forward to this summer when I get my Type-J kit and bags. I already tucked my exhaust up as much as I could when I installed my header and exhaust last year, so I should be good to go. I can manage if the exhaust touches the ground when I'm "laid out", just as long as I don't damage it.
