Just wondering where the best place is to pick up a set of lowering springs, looking for one with the most drop? Also will the camber be able to be adjusted to allow for lets say a 2 inch drop or would i have to buy a camber kit?
well Gravanatuning is a great place to shop. the lowest lowering spring you will find is the eibach sportlines. and they happen to be on sale i believe. you probably don't need a camber kit. my car is down 2" and a bit and my camber is fine. you may want to look into some aftermarket struts if you are going that low. koni yellows or tokico d specs are probably your best bet.
ECOSPEEDZ
eibach sportlines. 1.7 inch drop in front. 2.3 in rear
with any lowering you wanna get koni yellows. or koni reds they are a little cheaper.
no need for a camber kit. or you can get some ground control coilovers.
Gravanatuning and Carcustoms.net both great places
