Like the title says. Can I use tein pillowball mounts on my kw v1 coilovers?
I may be possible. You'd have to measure the shaft diameter of the kW vs the tein. I could probably grab a measurement off the teins on my car when I get home tomorrow.
Keep in mind too that the tein mounts are cupped to accommodate the edfc stepper motors so they may not allow you to lower as much as a stock mount (which may or may not matter depending one what you are doing with the car)
I've been riding on new oem strut mounts and they moan and groan and make terrible noises. I'm only lowered about an inch and a half ( two fingers between tire and wheel well). I just want the sounds gone. This is my daily but I don't mind stiffness as I'm all poly everything. Just want the sound gone
I recently acquired a set of kw v1s for next to nothing from someone.. what do I need to mount them to the car? Just mounting plates or do I need bushings as well? Wanna order all new so I can pull old junk struts out n be ready to put kws in
Thanks in advance
