Been running KYB mounts on my Tein Coilovers. Blew one of my bearings which was making a rubber to metal clunk. Not bad because it was only $5 for the bearing. Now what what are my options for an upgrade on mounts? Tein springs are 2.75 inches in diameter. Is there such thing as a front solid mount? Or are camber plates my only option. Thanks in advance!
I went with the Mookeh camber plates... like em....
Direct fit or needs modification?
A camber plate is a solid mount. It's just adjustable. If you wanted a fixed mount, you could easily piece one together with readily available parts.
Tein had solid and camber mounts for the coilovers they sold.
