How the heck do you press these into place? The control arm just wants to cut the lip off of the poly bushing. Any suggestions or help would be great?
Thanks
Jay
I haven't installed mine yet but I did some research and I remember reading somewhere that there was a metal ring that was left in the control arm after removing the stock bushing that had to be removed. Cut it with a hacksaw to make sure you don't damage the control arm itself.
I removed the metal ring before i tried to install . . . It isn't supposed to make a difference but these are the aluminum nbody arms
On the aluminum arms you would want to machine a beveled edge onto whatever side you press the bushings in from. A dremel should do the job pretty well. Then grease everything liberally, and it should pop in. I've done so many sets on J's, cobalts, and n-body arms that I can pop them in within a matter of minutes
Roofy wrote:On the aluminum arms you would want to machine a beveled edge onto whatever side you press the bushings in from. A dremel should do the job pretty well. Then grease everything liberally, and it should pop in. I've done so many sets on J's, cobalts, and n-body arms that I can pop them in within a matter of minutes
the aluminum arms already have one beveled edge, no need for machining. mine just popped right in using my vice.
There is no beveled edge on mine. This makes sense . . . I will give this a try! Thanks Roofy.
Whats up people?
I have yet to see a beveled edge on either cobalt or n-body aluminum arms. Good luck.
i just teared a bushing trying to install these! then i sand a beveled edge by hand with 320grid sand paper. and it went in. you need to make it go at an angle, not straight!
so i ordered another set just to replace the one i teared the lip apart!!!
cost me 75$ with shipping....
when i tore mine, i called up prothane and they shipped me replacement bushings for free...
seriously??? Damn... should of known that! didnt they tell you, you did not install properly, its your falt???
Hmmmm good call. I have the Energy Suspension ones. Think I will call them in the morning and tell them that the poly bushing just tore as I was trying to press in. As there is no instructions in the box how can they tell you it was installed wrong. One would assume press old bushing out and press new bushing in. Not press old bushings out then make sure there is a beveled edge and then press new bushing in!
You know, GM should have beveled that edge for better manufacturability on their end, they would have needed less precision in placing the bearings in the factory. You'ed figure they'd do that since practically all the plastic in the car has slotted holes so its easy to line up with all the different tolerances in the car.
Sponsored by:
Kronos Performance
i put my on top of my jack and then jacked the car up till they popped in i didnt have a press or a vise lol
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
Cavi2Sunfire wrote:i put my on top of my jack and then jacked the car up till they popped in i didnt have a press or a vise lol
Haha wow! Whatever works I guess!
Here is a very good write-up Misnblu did on the aluminum control arms from start to finish with lots of pics. There is some helpful info on installing the bushings near the bottom of the page.
So seeing this post after I messed up one bushing and not taking that ring out makes me mad. I installed the bushing anyways cuz I need my car for work till I get a new bushing, I'm getting a clunk on the bad side when I hit bumps. Think that's the bushing for sure that's causing that noise? I replaced inner and outer tie rod's swaybar and links ball joints as well.
