Stupid Strut Mounts! - Suspension and Brake Forum
Sunday, August 03, 2008 2:26 PM
I have an 03 Cavalier, lowered on kyb agx's with a 1.5 drop springs I have replaced mounts in back a few times and both fronts once now my drivers side is bad again, im to the point of going back to stock suspension do they make a better quality mount out there?? does anyone else get frustrated replacing these mounts?
GOD : The way, the truth, and the life.
Re: Stupid Strut Mounts!
Sunday, August 03, 2008 2:35 PM
95-99 style and you shouldnt have anymore front strut mount issues. I assume you are getting a squeaking/grinding/crunching noise.
Sunday, August 03, 2008 10:25 PM
mitdr774 wrote:95-99 style and you shouldnt have anymore front strut mount issues. I assume you are getting a squeaking/grinding/crunching noise.
Any way to use those with Basics?
Built 94-97 head for sale: http://www.j-body.org/classifieds/engine/47069/
Monday, August 04, 2008 2:09 AM
Wouldnt know as I dont have basics. Unless they were somehow designed to not work with the 95-99 mount it should work.
Monday, August 04, 2008 3:10 AM
95-99 mounts should work fine with the basics. theres really no different between the mounts except for the fact the 00+ is a 1 piece mount and the 95-99 is a 3pc mount
Monday, August 04, 2008 4:03 AM
okay thank you
Monday, August 04, 2008 8:31 AM
Moar Candy! LAWL wrote:95-99 mounts should work fine with the basics. theres really no different between the mounts except for the fact the 00+ is a 1 piece mount and the 95-99 is a 3pc mount
Wrong! The reason that Tein tells people to use the 2000 mount is cause it is also a lower profile mount that drops the car lower. If you are going to use the 95-99 mounts you are going to have to lower the car more in the front due to the mounts that makes your travel on your struts lower on them and harder on them. I hope that helps you. Sometimes you can put some grease into the 2000 mounts to quiet them down a bit.
Monday, August 04, 2008 8:36 AM
Buy the tein SS coil overs... Hello pillow ball mounts.
Tuesday, August 05, 2008 8:45 PM
just ordered some 97 cavy mounts
Tuesday, August 05, 2008 9:37 PM
probably too late but i have some for sale http://www.j-body.org/classifieds/suspension/51935/
Tuesday, August 05, 2008 11:01 PM
would it be any better to get an aftermarket brand like moog or something instead of just a stock replacement?
* * BIG FOR SALE POST * *
