Neon Brake Q - Suspension and Brake Forum
Neon Brake Q
Tuesday, November 27, 2007 11:02 PM
BTW its going on a 3rd gen
I need the fitting size to use the stock rubber hose of a cavalier to the neon rear caliper. I read the sticky and im not seeing the fitting size. Unless at the very beginning the fittings suggested were the ones needed. I just didn't quite know if that was for stock brake lines.
Thanks
Re: Neon Brake Q
Wednesday, November 28, 2007 7:07 AM
I'm kind of lost on what you want to do here.....
There is a rubber line that goes from the unibody to the axle, and then its hard bent to the wheel cylinder. You want to attach a rubber hose to the end of that to go to the caliper?
Re: Neon Brake Q
Wednesday, November 28, 2007 7:24 PM
XRP p/n's--
FEMALE TO MALE BULKHEAD ADAPTERS
410103 - M10x1.0 Inverted Flare..........3AN-- They connect the stock 3/16th brake lines into the 3an male fittings on the SS brake lines.
Crush washer seal adapters to neon Calipers
402933 - 7/16 x 20 thread seal ............3AN to SS brake lines
Crush Washer seal adapters to J body front calipers
425033 - M10x1.5 thread seal ..............3AN to SS brake lines
XRP catalog ( PDF) file
Thats the best i can do for ya man. Hope that helps.
Edited 1 time(s). Last edited Wednesday, November 28, 2007 7:25 PM
Re: Neon Brake Q
Thursday, November 29, 2007 6:58 PM
Depending on the caliper, you may need an M10 x 1 banjo
Re: Neon Brake Q
Thursday, November 29, 2007 11:15 PM
Cody that is what I was looking for. sorry for the rubber hose thing I was not thinking about the line being a solid tube......sleep deprivation for ya.
Re: Neon Brake Q
Thursday, November 29, 2007 11:39 PM
Kardain wrote:Depending on the caliper, you may need an M10 x 1 banjo
What caliper may this be? I got my parts from a 97 neon sport, but I didnt buy the calipers from the yard since the auto parts store would only give me a $15 core for a junk yard $20 part / per side =$40 for both. I spent a high $90 for what I needed - the caliper. Im not too happy about the jacked price I paid.
Re: Neon Brake Q
Thursday, November 29, 2007 11:41 PM
I used 04 SRT-4 calipers (the only ones I could get my mitts on w/ out waiting)
No real difference than the Neon ones, just the fitting was different.
Edited 1 time(s). Last edited Thursday, November 29, 2007 11:41 PM
Re: Neon Brake Q
Thursday, November 29, 2007 11:46 PM
I see, Yeah Im not going that far on this car. This will be the only upgrade to the vert so far. all stock and bad brakes. man I miss my hardtop.......
Re: Neon Brake Q
Thursday, November 29, 2007 11:48 PM
This may be a silly Q but do I have to use a SS line or can I use say a goodridge line?
Re: Neon Brake Q
Friday, November 30, 2007 5:15 PM
http://www.j-body.org/forums/read.php?f=3&i=92768&t=92768&p=13
its also on pg.13. a note about what was posted above - the fittings you need are not inverted flare, they are bubble flare. also, for the caliper, you don't need to use that type of fitting, you can use the stock banjo bolt with a new 7/16" banjo.
SS lines are the easier way to do this since they are sold everywhere. goodridge is a brand for SS lines, just like earls, and others.
