what struts should i match with my eibach sportlines - Suspension and Brake Forum
Wednesday, June 27, 2007 1:18 PM
i have monroe struts with eibach sportline kit. the dealer near me told me this was a good setup. sure enough it rides like crap. i was lookin into it and the monroes are a stock replacement strut. should i go with koni yellows or eibachs in this situation. i want them to be daily driven.
Re: what struts should i match with my eibach sportlines
Wednesday, June 27, 2007 1:27 PM
koni yellows or tokico dspecs
Wednesday, June 27, 2007 1:30 PM
would the d-specs handle that drop? i was told they wont. but if they do then nice cause there a little cheaper than the eibachs
Wednesday, June 27, 2007 1:35 PM
the eibach what? dspecs are plenty good enough to handle the drop
Wednesday, June 27, 2007 1:36 PM
JBO_FTW wrote:would the d-specs handle that drop? i was told they wont. but if they do then nice cause there a little cheaper than the eibachs
Yes, they will. Several members here are running that combination, including myself.
    Shop Manuals, Brochures:www.kenmcgeeautobooks.com
Wednesday, June 27, 2007 4:16 PM
nice! i appreciate the feedback. is it a good ride? more bouncy or more stiff
Wednesday, June 27, 2007 7:15 PM
JBO_FTW wrote:nice! i appreciate the feedback. is it a good ride? more bouncy or more stiff
The sportlines are always going to give a fairly stiff ride no matter what strut it's used with, however the D-Specs give you a good amount of adjustability within that range. At their softest setting, the ride approaches stock-like comfort but is a bit too "wavy" for my taste. When dialed in a bit stiffer, the car handles like it's on rails. You'll feel the bumps, for sure, but you definitely won't be bouncing. Odds are you'll be able to find a "good ride" somewhere in that range.
Wednesday, September 23, 2009 1:57 PM
sorry for the ressurection but i was just searching about struts for the sportlines and im curious to what the adjustment is like? is it something that can be done while the car is on teh ground? or do i need to jack it up/lift it
Wednesday, September 23, 2009 2:16 PM
On the Tokicos/Konis/KYB's and most other brands, there is an adjuster on top of the strut that you turn to soften/stiffen the strut's rebound/compression...as long as you can pop your hood and trunk you'll have access to them. Some high level struts have the adjuster at the bottom of the strut, but you can still usually turn the wheel or reach under the car/through the wheel spokes and adjust them.
Wednesday, September 23, 2009 2:45 PM
ncie sounds good, thanks for the info
Tuesday, March 08, 2011 1:09 PM
Are eibach sportline lowering springs good or not?
98 cavalier
Custom interior
Custom CAI
NGK spark plug wire set
2 12 in alpine type 2
Tuesday, March 08, 2011 4:55 PM
yes
Tuesday, March 08, 2011 5:14 PM
blucavvy wrote:yes
i think they look good a nice dd drop
Sig thanks to bxmobkrazey on gmscf.com
Tuesday, March 08, 2011 9:37 PM
Whats a good match with them?
Ground control struts?
98 cavalier
Custom interior
Custom CAI
