will an 03 Cavalier 2.2L Ecotec DC Sports CS-2 Front Strut Bar fit an 02
thanks reds
Yes it will but i would suggest getting a vibrant performance one. It is a little cheaper and a lot more solid! I have both front and rear on my cavalier! It was a great mod. I ordered mine from neverenoughauto.com. I got blue ones by calling the store.
How do you figure the Vibrant..Bar is better than the DC Sport bar..The Vibrant bar has links on the ends which can cause movement..Dont care what the rest of you say it will flex under stress...The DC sport bar is a one soild unit..All welded once bolted on cant move any where..And will clear the computer as it has a indentation for it..Is it worth the money for the DC Sport..Hell yes..
I agree w/ Jason. I have the DC Sports bar and LOVE IT! The only other bar I would go w/ is the GM one from a junk yard. You could actually find one in the junker for like 35 dollars or cheaper. Good luck w/ it man and I would again tell ya to get the GM one or the DC one.
The adjusters allow you to set a preload on the towers, which is something you can't do with a solid bar.
fortune cookie say:
You will never adjust it enough to make a difference...Plus all welded is stronger and it is made from Carbon Steel which is stronger than Aluminum..So in the end the DC sport is lighter, stronger and will do more for you at the end of the day..
