Torque Specs for EasyStreet front air struts... - Suspension and Brake Forum
Monday, May 14, 2007 9:39 PM
Anybody have them? Or those with the EasyStreet set-up, how do you keep yours tight?
Mine seem to get loose after a while, then the steering wanders, which is VERY dangerous.
(The Front Air Struts are adjustable at the top mounting hole)
You can see it in this pic. The top hole is notched out more than the bottom one.
Thanks!
Re: Torque Specs for EasyStreet front air struts...
Monday, May 14, 2007 9:44 PM
Unless I'm wrong the notches are for camber bolts....not sure why they are becoming loose tho
Monday, May 14, 2007 11:24 PM
i have always had the same problem. at least its not just me. i just try to tighten them every once and awhile
Monday, May 14, 2007 11:47 PM
the notches are so you dont HAVE to get camber bolts
Tuesday, May 15, 2007 3:54 AM
what kind of nut and washer are you using? i never had a problem w/ mine. do you have the nylon nut?
Thursday, May 17, 2007 6:22 PM
StrippedCav98 (Now Quotable) wrote:what kind of nut and washer are you using? i never had a problem w/ mine. do you have the nylon nut?
They didn't come with any nuts or bolts for mounting them to the knuckles. I used the factory knuckle bolts. No washers either.
Do you suggest some lock washers?
Also, somebody told me 140 ft lbs on the strut bolts (at the bottom, not the top)
Sound good?
Thursday, May 17, 2007 6:47 PM
I've never had problems, just used the washers and nylon nuts, going on 3 years!!
Friday, May 18, 2007 10:15 AM
96projectz24 wrote:I've never had problems, just used the washers and nylon nuts, going on 3 years!!
Anybody got any pics of these nylon nuts & washers? Maybe my kit got shorted?
Sunday, May 20, 2007 9:31 AM
