Axle nut socket size - Suspension and Brake Forum
Wednesday, June 21, 2006 10:28 PM
Hey guys!
Working on replacing an engine. What size are the axle nuts? To take the axles off the car. Thinking 33 mm here.
Re: Axle nut socket size
Wednesday, June 21, 2006 10:30 PM
never mind! Found it. 30 mm
Thursday, June 22, 2006 10:55 PM
30mm works, 1 and 1/8th inch seems to fit a bit better though
14.82 @ 97 mph
Friday, June 23, 2006 8:46 AM
It's actually 28mm. But 30 will fit.
Saturday, June 24, 2006 7:44 PM
C.T.S wrote:It's actually 28mm. But 30 will fit.
Uh, that's a pretty big difference. Using a 30mm on a 28mm nut would round it off for sure, especially with how tight the axle nuts are.
1983 Camaro Z28
Saturday, June 24, 2006 9:24 PM
Aparently you haven't tried or you would know it works.
Sunday, June 25, 2006 1:06 AM
depends on the cut of socket....... but I'm pretty sure GM lists it as a 30mm.....
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Sunday, June 25, 2006 9:01 AM
I just changed my front hub/bearing a few weeks ago and I used a 30mm.
It's a 99z24 so I would think they are all the same.
Sunday, June 25, 2006 7:09 PM
my 30mm was loose.....
Wednesday, July 12, 2006 7:49 AM
Well I'm glad mine fit cause I paid almost $17 for the socket!!
Thursday, July 13, 2006 9:00 PM
Go to a AUTO PARTS Store, ask them for the correct size, I did and it was a 30mm.
My Myspace Page
Thursday, July 13, 2006 9:28 PM
Isaak wrote:my 30mm was loose.....
Yeah people can ask whoever they want, it's still 28mm, and 30mm will still fit (if it's 6 point).
Friday, July 14, 2006 9:48 AM
30mm was a little loose, but worked fine w/ impact wrench.
Friday, July 14, 2006 1:04 PM
yep my 30mm worked, just was loose, and it was an impact socket (6pt)
Sunday, July 16, 2006 1:38 AM
Maybe it's a different year thing?? I've only worked on 98 and newer... and all of them were 30mm... there is no way in hell a 28 would fit.
And the N-body stuff we swapped was 34mm....
I have a 28mm socket here... no way it'll fit my 00 axles nuts.
Monday, July 17, 2006 8:59 AM
John Lenko wrote:Maybe it's a different year thing?? I've only worked on 98 and newer... and all of them were 30mm... there is no way in hell a 28 would fit.
I have tried both the 30mm and 28mm, and only the 30mm fit on my 2002 aswell.
Monday, July 17, 2006 9:06 AM
Did they change it some year? My 97, 95 and 95 GAM all are 28mm.
