So to make a long story short. I need a new rear axel because I hit some ice this last winter and bounced off a wall and bent my rear axel. so I need to know what rear axels will fit my 2004 cavalier. will the older cavalier axels fit my car? I need a new one. Help!!!!!!
95-05 are all the same. Read the FAQ for more info.
C.T.S wrote:95-05 are all the same. Read the FAQ for more info.
Got different part numbers for FE0 FE1 and FE2 though...
it really depends on what susp code u have fe0 has no stabilizer and no link front or rear ......(i know cause thats what i have)
now the other 2 im not sure about but i'd assume one was just the front sway bar kit andthe fe2 would be the full kit front n back ..... so .................in saying all that bs
if u know u have a fe0..... it shouldnt matter what axel u use fe0 fe1 fe2 the differences between them shoudl only be that if u mount a fe2 axel but you have a fe0 sysp code for ur car ... your fine ......
but if u have a sysp code fe2 and you want to use a fe1 or fe0 sysp coded axel .... your gonna be in trouble ...... you have nothing to mount your sway bar kit to .......
hope this helped ......
and foreveryone else .....please correct me if im wrong
thanks !
