I just installed my BC2 kit yesterday and need less to say the kit is WAY to low with the sprint springs I have(the front of my shoe barely fits under the rear bumper). Can anyoen give me some ideas on what springs to use to lift my car up a bit. I though about getting some coil-overs but I cant afford full and dont want the ride of sleeves. O and I have koni yellows on the car to. Which are set completely hard in the rear at the moment.
I'm a fan of the Koni Springs that come in the Sport Kit. They are sold individually now as well. Those and Eibachs.
5K PB: 24:50
10K PB: 54:26
What are you talking about when you say you don't like the ride with coilover sleeves? A set of Ground Controls on your Koni Yellows will ride as good as any other setup out there.
Since you've already got the Koni's, that's the solution I recommend, but don' t get the standard springs they come with. Any company that deals Ground Control can order them for you with whatever springs you want. Check my registry for the size I recommend for you, so you can ride at nearly stock height when it suits you but still drop 3" for shows.
Wild Weasel wrote:What are you talking about when you say you don't like the ride with coilover sleeves? A set of Ground Controls on your Koni Yellows will ride as good as any other setup out there.
Do you have any type of system in your car?? I have a fully built trunk. I also added a shaved trunk and prostock spoiler the combo fo the 2 lowered the back of my car an additional 1/4" or so. What spring rate would recommend??
