STRUTS - Suspension and Brake Forum
STRUTS
Tuesday, March 07, 2006 10:12 PM
Hey all i use to off road trackers. we ude to get struts for the rear of a mustang gt. they are 2" longer and would give u a 2" lift so my question is i got a 2001 z24. and i like the factory ride an not lookin for performance but want to drop it 1" to 2" is there a car that has shorter struts that would fit undr this car? thanks
Re: STRUTS
Tuesday, March 07, 2006 10:24 PM
Read the FAQ
Re: STRUTS
Wednesday, March 08, 2006 8:12 AM
struts DO NOT affect height, springs and coilovers do.
-Chris
Re: STRUTS
Wednesday, March 08, 2006 9:14 AM
C.T.S wrote:Read the FAQ
IamRascal wrote:struts DO NOT affect height, springs and coilovers do.
Word to both.
Dave, please use punctuation where necessary. I got a slight headache reading your post.
Re: STRUTS
Thursday, March 09, 2006 2:06 AM
Sorry boys i wrote that at work the other night, very tired. what i ment was the whole spring an coilover unit out off a early 90s mustang was 2" taller and would bolt in place. Is there a car that the whole unit is 2" shorter and will bolt in place.
Re: STRUTS
Thursday, March 09, 2006 5:30 AM
You want to life a J-Body?
I don't think anyone makes anything that would lift it more than ~1/2" (bags or special made GC coilovers).
Re: STRUTS
Thursday, March 09, 2006 6:10 AM
no he wants to swap out the rear struts off another car onto a j to make his car lower. i dont know of any car that will bolt right up to it but i dont see it working
Re: STRUTS
Thursday, March 09, 2006 8:28 AM
Tien h-tech have VERY similar spring compression pound rates, as compared to the stock spring. So I would say that with some lowering struts sent on their lightest setting would yield a fairly stock ride with a 1" drop.
Re: STRUTS
Thursday, March 09, 2006 11:20 AM
You can put H-Techs on stock struts. Just don't be suprised when they wear out (the struts) after two years. You can also use Suspension Techniques (1.1" drop).
Re: STRUTS
Thursday, March 09, 2006 12:34 PM
Struts made for our cars do not affect ride height, but his question is still valid. If there were a strut made for some other car that could be bolted to ours... and that strut had the spring perch an inch and a half lower... then they'd lower the car.
Of course, I don't know of any such struts. But again... the question is valid. Don't be so quick to pounce.
Re: STRUTS
Thursday, March 09, 2006 2:23 PM
it doesnt sound safe at all... im sure someone can tell you why
Re: STRUTS
Thursday, March 09, 2006 4:27 PM
I pounced, and then provided the correct information .
Anywhosit for the amount of money you'd spend purchasing used struts from another car you could have any number of lowering springs.
Done thru e-bay, you can get some AGX's and H&R's all together for $600.00 or less. Gravana tuning sells the koni sport kit that comes with springs and struts for a decent price.
-Chris
Re: STRUTS
Thursday, March 09, 2006 6:55 PM
I don't know about the rear but there isn't a whole lotta clearance between the spring perch and tire on the front.
Re: STRUTS
Thursday, March 09, 2006 8:57 PM
Thanks guys for all the responses. Ya mike i never thought about the spring perch!! as for safe i can show you 3 trackers that are daily drivers that use this for a simple 2" lift and have been for years. price would be nothin i can get most all factory parts for next to nothin. but it wouldn't worthe perch would be sittin on the tire. Thanks All this is a great site love it
Re: STRUTS
Saturday, March 11, 2006 9:53 PM
valid question.... oe strut that would be able to handle a lowering of a 2'' of our cars w/ the same bolt pattern...guys i'll look this up at work tomorrow thru the books again to see if there is anything that has a compression of 2inchs lower thna ours so you could use it so that it wouldn't "bump" and bottom out when you went over bumps... (like mine)
Re: STRUTS
Saturday, March 11, 2006 10:39 PM
You can't just change that stuff. It's not that simple.
If you lower the car you have to raise the spring rate to compensate. It's a trade-off.
The higher spring rate will overpower, and destroy, stock struts (and aftermarket not meant for lowering). Then you bonce all over the place and have other problems as well.
