The hazards and parking lights are working fine but niether of the blinkers will work. Has this happened to anyone else? Any ideas on how to fix it?
1988 Z24 Coupe
Kenwood CD player
This is a EASY FIX!!! You will need to pull the plastic trim below your steering column/fuse box area and ecm plug.NOW behind that and up there will be 2 round fuse style flashers.One is for signals the other is for hazards.Just turn on your flashers so YOU know which fuse is working.The fuse is about a half dollar size (actually a touch smaller) and about one inch tall and round.It will have a two prong plug in connection.Simply remove the turn signal flasher(fuse as it is technically called) and replace it with the EXACT part.This are wayyyy oldschool and auto zone,napa,advance,oreillys have these all day long for about 3.50 or so.Basically your flasher fuse is umm done.
Note it may be mounted on a bracket and just remove the plastic from the kick panel (fuse box towards the radio(to the right). Piece of cake.
