1994 2.2 performance - Second Generation Forum
Tuesday, November 27, 2007 5:41 PM
Ok, I am obviously new here. I am almost definitely buying a 94 Cavalier with the 2.2 and 5 speed. It is a coupe and only has 104,000 miles. Black with I think grey interior. New tires, water pump. For $600 and it runs great. I have found so far just electronics upgrades you know like aftermarket programmers and what not. I am looking for a header, high flow cat, and a good cat back(i might fab an aftercat exhaust if I cant find one i like enough). But what about air intakes? Performance Clutches? Turbo? I know you can make your own turbo set up but is there a bolt on available? I do not want to swap engines as that isn't really an option right now but if I were to do so I would go with the 3800 supercharged because I saw one on cardomain.com in a 94 and thought it would be sweet. I also know about ignition upgrades but any and all performance part help you can give me would be great. Thank you for the help.
Re: 1994 2.2 performance
Wednesday, November 28, 2007 6:47 AM
turbo.. I doubt you'll do just because of the price ratio factor. you can get a few cheap mods ie: pacesetter header will help, you can also do a ostrige type of ecm which will eliminate speed limiter ect. and thier are type of bolt on turbo's but alot of modifcations goes into one. like i did. your best bet is to drop a 3400 or what now people are doing is a 3500 swap.
hope it helps
**changes are here**
Wednesday, November 28, 2007 7:11 AM
Go to V6Z24.com and find the General FAQ in the General forum. All the links are there for the 2.2.
You aren't going to find any parts specific for a 94. The engine is the same from 92-97, so any engine specific stuff will work. Turbo kits will need to have tubes rebent, etc, since the 3rd gens have a different unibody.
Wednesday, December 05, 2007 1:14 AM
we have a speed limiter...
my 93 car red lines in final gear and then hits the limiter (for exceeding redline)... radar about 112 mph on my Cop buddy's radar on a closed course
Saturday, December 08, 2007 5:39 AM
It seems to depend on the year, calibration, and trans type. Our 93 VL never appeared to have a speed or rev limiter. At least I couldn't find it when I lived in Montana and had lots of miles of straight, flat, empty road to use when looking.
-->Slow
Tuesday, December 11, 2007 10:49 AM
The ultimate sleeper: A gen 2 cav with plastic bumpers and the chevy steelies (the styled steel rims like my '91 had) with turbo.
2010 Honda Fit LX
Tuesday, December 11, 2007 6:48 PM
How about plastic bumpers, VL trim, and steelies hidden behind hubcaps? With turbo...
-->Slow
