i got another rear manifold form a 3400 yesterday and it still had the o2 sensor on it and my car is runnin rich so im wondering if i can try swapping them?does anyknow how if it does actually hook up will it be wired up properly?also damn was taht DP a bitch to cut thru with a hacksaw :hahafu: stupid thing has a tube inside of a tube :rant:
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
its no go
lol damn thing has 4 wires where as the 3.1s have 1 or 2(cant remember)
the input from it SHOULD be the same, the 4 wire is a heated 02, if your using the 3100\3400 vcm then use the 4 wire, if you have the 3.1 ECM use the one wire.
chris
'02 Z-24 Supercharged
do u know which wire i use?
what ECM\VCm are you using,?
chris
everythign in my car is from my 3.1 still,i dont ahve my hybrid in yet
if your using the 3.1 ECM just use the one wire O2,
i stuck with obd-1 with mine, just get a custam E-PROM burnt for it latter on when your tuning it.
chris
use the 1 wire o2 -- the heated o2 use a different calibration, but on top of that, you'd have to bring fused power to the heated 02 to make it work, and it needs to be regulated at (either 5 or 12v) to be accurate.
--LL
-=[2004 JBody Bash - '82-'94 Street Modified - Third Place]=-
http://www.turbochargedsoul.com/
[TZ3] 1994 Cavalier Z24 Convertible, Automatic, (Boost around the bend)
[TZ2] 1993 3.1 Liter V6 Intercooled TurboChevrolet Cavalier Z24 Convertible 5 speed
:: REST IN PIECES :: (Parts available, PM me!)
1994 Subaru Legacy L AWD Wagon 5sp/EJ22 - Daily Driver
N3LEE - Amateur Radio
