Everything Stef said is right on. If I may I'd like to add a few of my own thoughts.
I didn't beam polish my rods because there's so little "meat" on them I didn't like the idea of removing any. I haven't heard of one breaking anywhere but at the big end anyway which is usually from the stock bolts stretching. ARP bolts are a must.
Unless you want to do some welding and fabrication to mount a large TB centrally I'd use the2.0 MPFI intake with the 54 MM Fiero TB. You get the raised TB location and the Fiero unit will bolt right up after you open the hole for the throttle blade. A hell of a lot easier then making the Fiero TB fit the turbo manifold.
Cometic's gasket is sized for the stock head bolts. If you want to use 1/2" studs you need to open the holes up yourself. You'd think since they make it they could do it for you but they told me "no". When I opened mine up I didn't deburr it well enough so the little shards left made it leak. To do it right you need to drill out the rivets, split all 3 pieces apart then drill it and deburr it. I never felt like trying mine again after it leaked the first time.
If you O-ring the block or head you may not be able to seal the coolant passages well with a stock type gasket. It took me a while to get mine to seal up but I did it. I had no luck finding an off the shelf copper gasket in the US other than the "head saver" shim Fel-pro and NAPA sell. That's too thin to act as a gasket on it's own though. You'd have better luck going to someone in the UK for one. Maybe Stef has a contact on that?
Some US places will make one for you but you either have to take a picture of one so they can see if it's in their database or send them one to copy. Prices range from $75 bucks to $175 bucks and timeframes are usually a couple of weeks.
There are probably as many people who have had luck with copper gaskets on street cars as people who haven't. I never have so I stay away from them.
The GP turbo is worth 30-40 HP as stated and you can easily make 235-240 hp with a completely stock engine, GPT, and bolt ons like exhaust, air filter, intercooler.
I'm using a Mitsubishi TD06 17 C from a Syclone/Typhoon and in completely stock configuration it spooled up very fast and will support around 360 HP. That Mvaux exhaust manifold is excellent and a very good bargain at $125 bucks or so. The stock 2.0 exhaust manifold is very small inside so why waste time with it? You could fab one up yourself of course too.
I'm not aware of any adjustable fuel pressure regulator that swaps into our cars. Even if there was I don't know how you'd adjust it under the intake manifold unless you have arms like a chimpanzee. I'd cut and flare the fuel rail to adapt it to a more conventional AFPR and call it a day.
A Walbro 340 fuel pump fits right into the tank and will support pretty much all the power we'll ever make. The SY/TY, Turbo TA pump is also an easy swap if you want to go that route.
The Mopar Super 60, 52 lb/hr injectors area super deal at $35 bucks apiece new. Problem is you'll need to use an FMU or hop onboard the OBD1 tuning train. There are a few different tuning programs you can use like Tunercat or Tunerpro but there's some expense involved for cabling, a laptop, an emulator, etc to get started. Plus, if you're a cement head like me expect a long, troubled learning curve.
I don't know where the "350 HP head flow barrier" number originated from but no one has shown me any proof that it's real. I know the head flow numbers off my head and would be eager to compare them to anyone else who has any.
I didn't know there was a Euro 16V head with a distributor hole. Next time you come across one Stef let me know what it would cost me to buy it and ship it here. I'll add it to
my collection. My Amigo has no distributor hole.
I'm not sure what mods were done to the 1.8T auto transmission but I'm wiling to bet the 2.0 version is stronger. The 2.0 turbo code is PPC. I can tell you what has been done to mine to get it to live if you want to email me. It's too lengthy to get into here. I dont think you have to worry about axle shafts since no one has ever reported snapping one that I've read about. At least not with an automatic anyways.
Tony
Tony
1987 Sunbird GT turbo convert
Ported intake, Fiero 53 MM TB, 52 lb inj, ported and flowed head, tube header, Mitsu TD06, ARP rod
bolts/head studs, adj cam sprocket, 4" x 12" x 31" FMIC, Paxton AFPR, modified 125 trans/LSD
unit/3.42's, custom chip tuning, Alky Control Methanol injection
13.61 ET at 101.44 mph, 262 WHP/350WTQ
2009 Pontiac Solstice GXP roadster, 2.0 turbo w/GMPP exh, CAI and turbo upgrade, 290 hp/325 ft lbs
1969 Olds 442 convert
400 Eng, 200-4R trans, 3.73 posi, power everything, OAI
