skyhawk resto - First Generation Forum
skyhawk resto
Saturday, October 06, 2012 3:28 AM
i "ve been busy working on the hawk and things are going well. here is a list and some pics of the progress.
patch panels welded in front of both rear wheels.
new radiator installed.
cleaned up the engine bay.
new brakes all the way around.
cleaned and painted rear axle and swaybar install'
undercoating of wheel wells and painting of plastic parts
i am going to start sanding and priming the body a section at a time, a tuff and messy job. i hate dirt!
Re: skyhawk resto
Saturday, October 06, 2012 7:47 PM
Looks like you have done some nice work there.
Keep us updated.
Re: skyhawk resto
Saturday, October 06, 2012 9:48 PM
Always fun when doing resto work.Doing it in steps makes each part better a little at a time.I see your engine has some serious oil on the pass side,maybe your oil pan is the culprit?I know they can leak like a river if not done thoroughly and I mean stupid clean and great gasket seale like permatexs the right stuff(that is the real name of it).
Re: skyhawk resto
Sunday, October 07, 2012 2:47 PM
i did have a leaking valve cover ron. i think it must have been leaking for years before i got the car a couple years ago.i think the former owner was very sloppy when removing the oil filter as there is tons of crud in that area. i scraped alot off already.iam thinking about getting it steam cleaned but am worried about water in the electricals. the oil pan does have a small leak but i cant justify all that work with the amount of oil it is losing right now(leaves about a spot the size of a half dollar after several days of sitting) if i get to the point where i think it has to be done i will probably be asking you and everyone a lot of ?s
Re: skyhawk resto
Sunday, October 07, 2012 6:51 PM
Coming along
Re: skyhawk resto
Sunday, October 07, 2012 7:40 PM
Great photos!! Great work to go with them :-)
So unusual to see an OHV in a Pontiac. Most all came with the OHC. Parts and reliability are on your side though! I've got one of each and the OHC is a very finicky design. I think the worst design on your engine is the coil location. I also noticed with interest that you have the power steering pump with the reservoir , the OHC engines have the pump with the reservoir located on the firewall. I had thought this was proprietary to Pontiac/Oldsmobile/Buick. Turns out it was dictated by engine installed.
I had a valve cover gasket go too. Had to use a cork design, the neoprene didn't hold for me. LoL, the passenger side subframe on these do tend to be very well oiled/lubricated....I repainted the drivers side, but the oil from the filter changes made this side impossible to do, and hardly necessary!!
Just a little FYI. Transaxle from the OHC wont interchange with OHV. The starter location is on the firewall side on the OHC.
Keep the photos & Updates coming!! :-)
Re: skyhawk resto
Sunday, October 07, 2012 7:49 PM
Opppsssss...I keep thinking you have a Pontiac. I'll have to do some homework and see if the Buicks came with the Brazil engines. I know the Cimarron used only the OHV , none rolled off with the Brazil engine - you'd think Cadillac could have benefited from having the Turbo option in their Models.
Re: skyhawk resto
Sunday, October 07, 2012 8:17 PM
Orlen--my '85 Hawk does have the Brazilian 1.8
Re: skyhawk resto
Monday, October 08, 2012 4:46 AM
Thanks Wayne!!
It's wonderful to have some Buick owners amongst us to keep us informed!!
We have only a lonely - one such example running the local streets here. Seems to be a late version, solid white 4 door, but in excellent condition. Never seen to be in the right place or with my camera to catch a photo though.
Re: skyhawk resto
Sunday, December 02, 2012 9:49 AM
i'm going to be ordering some new carpet soon. can someone tell me the factory code colors from these build sheets? i also could use the names of a few good suppliers. thanks.
Re: skyhawk resto
Sunday, December 02, 2012 12:19 PM
It is right at the bottom of the last picture. DIS Lacquer WA-L8574 U8592 27c
Lacquer
L-8574 = L means Lower body - Dark Blue
U-8592 = Upperbody - Light Blue
27c= Clear Coat Blue Metalic
http://paintref.com/cgi-bin/colorcodedisplay.cgi?gmcode=WA8574&rows=50
I believe those are correct. A paint show can help you but It should get you 80% of the way there
Re: skyhawk resto
Sunday, December 02, 2012 3:07 PM
i'm sorry rob i should have been more specific, i am looking for the interior color codes for the carpet and interior trim.
Re: skyhawk resto
Sunday, December 02, 2012 5:50 PM
If I remember correctly, I think I saw carpet codes on the list that is on your trunk spare tire cover.
Re: skyhawk resto
Sunday, December 02, 2012 6:00 PM
27I = interior trim color dark blue
(Quoting a past member)-"Never underestimate a First Gen"
Re: skyhawk resto
Sunday, December 02, 2012 8:00 PM
Get carpet from here.
http://www.ebay.com/itm/89-90-91-92-93-94-Chevrolet-Cavalier-Convertible-Carpet-/120982423706?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c2b1d489a&vxp=mtr
I ordered the 801 a few years ago. It was the best carpet I ever found for the price. I also paid them an extra $40 for the molded trunk carpet. It is exactly like the OEM carpet. You have to trim the edges a little, about 4 inches on my coupe and a lot for the back seat since it came about 2 feet too long. I also had to cut holes for the shifter and seats. It was amazing. Jbodies never came with jet black carpet. Just pick the color that is closes to yours or that you want. Also the picture shows a two piece carpet but mine was one solid piece even had padding on the back and the plastic rubber for you driver and passenger floor.
Re: skyhawk resto
Monday, December 03, 2012 2:15 AM
Rob Dotterer wrote: Jbodies never came with jet black carpet.
Yeah they did. Mine has black carpet and I've come across a few in a junkyard years ago as well.
http://www.accmats.com/ in case you want a customized carpet.
Re: skyhawk resto
Monday, December 03, 2012 4:09 AM
They came with a dark greyish black. It was never jet black.
Re: skyhawk resto
Monday, June 24, 2013 4:26 PM
well i finally got some ambition and time to work on the hawk. i have the roof and left rear qtr all sanded and now ihave a liitle filler to put on . i bought one of those gun style sandblaster for little spots where the sandpaper just cant get at all the rust. it works fairly well you just have to stop and refill it every 2 minutes. i also removed the rear bumper, sanded,primed and painted it just for insperation to get myself moving on this car. there always seems to be something else i have to take care of. theres an old saying life is what happens after you make plans. anyway here"s a few pics
i"m going to work my way around it a section at a time that way it doesnt seem to be such a monumental task
Re: skyhawk resto
Monday, June 24, 2013 7:52 PM
I might have to get one of those sand blasters myself!! What kind of Compressor are you feeding it with?
It is so easy to get overwhelmed with the entire project right in front of you, John. You are doing a Great Job on a has to be a very Rare Buick!! Keep going at your pace. Enjoy the Journey and try not to worry about the destination!!
Re: skyhawk resto
Monday, June 24, 2013 8:18 PM
Yeah....great progress John....very inspiring. I have that same journey to travel once my garage is cleaned up after the GT disassembly project. Though I do want to mock up my car with all the GT items first, then do panel fit and tweaking before I get into the body work where you are at.
I am curious why you decided to sand the paint substrate, instead of strip to bare metal? If you don't have putty lying under the surface to redo, I like to strip to bare metal so the new paint is factory straight. I also think it takes a bit more time to fill in scratches and paint nicks, than it is to just start over by stripping to bare metal with a chemical stripper. One time I stripped my 87 Trans Am panel by pane in my drive way. I used a chemical called Captain Lees Metal Prep and Etchant. It would protect the bare metal from rusting until you were ready to paint the car, then it was sanded off so as not to effect the paint when it was applied. That stuff was so good, that it is also used to remove surface rust. During the middle of that process, a hurricane came up the coast and rained on the bare metal T/A for 2 days. I was so stressed at what the aftermath of the metal was going to be, but the car only sustained a tiny bit of rust. It was easily removed by reapplying the Captain Lees which ate the rust away and reprotected the metal. 2 weeks later, I painted the car with no problems.
I also like your little sandblasting gun. Does it clog easily? I hate my big outdoor blaster because the high air pressure clogs it easily and the slightest bit of moisture in the air line also clogs it easily too. I now just use Captain Lees to chemically strip most of the rust on my bodies. I used it last year to remove the 85+ year old rust on my 26 Willys Overland touring car.. It was amazing to see the shiny metal come out from underneath the rust on that old tin.
I see you painted the endure rear bumper. Did you add a flex additive to the paint or just shoot it hoping the paint would not spider web crack? What type of paint did you use? Was it base coat clear coat, enamel from a gun or rattle can?
Re: skyhawk resto
Sunday, October 20, 2013 12:36 PM
well the summer went by too fast and i wont have time to paint the hawk this year. all the body work is done and its ready to be primed but its too cold here now to shoot paint. time to roll it into the corner of the garage, put the cover over it and wait for spring. my wifes vert is already in storage. she drove it all summer with no problems at all. i even got to take it out a few times! heres a few pics of where i am at right now. with my new spray guns just waiting to be used
Re: skyhawk resto
Sunday, October 20, 2013 9:31 PM
Looks bad yet looks really good with the body ready for some color.Nice fixes and I know the key in paint is prep.I myself may buy a paint gun hvlp to paint a deck lid for sunny.I am just working on finishing up some projects from spring to summer now fall.Car does look a ton better even in the prep stage.
Re: skyhawk resto
Monday, October 21, 2013 7:14 AM
Can't wait to see this in new paint!
Re: skyhawk resto
Monday, October 21, 2013 2:23 PM
NIce progress.
It is a journey, not a destination...
Re: skyhawk resto
Monday, October 28, 2013 6:11 PM
It is Wonderful to see some old 1st gens getting such TLC!! With those 3 guns I am excited to see what you come up with! Just think, this will be your last year looking at your Hawk in this condition ever again - so don't wince too hard. I am still getting used to the paint job I completed this year on my old 'Bird- myself. Seems like it happend so fast I didn't get time to soak in the transformation....LoL
No doubt it will be an exceptional looking very rare J you will have when finished
Keep up the efforts - and Thanks for sharing with us John!!
