ok guys... i've had a few experiences in tuning more than a few jbodies, and I'd like to offer my expertise to the north east
I'm based in bordentown NJ, which is close to philly and a few other busy towns... my area code is 08505
i have an enhanced i/o version of HPT
I specialize in AFR and ignition street tuning. I've worked with both naturally aspirated and boosted Jbodies.
my real specialty is ecotec engines, but i've messed with OHV and have yet to see a 2.4 ecu
basically, drop me a PM and we can discuss details of tuning your car. you MUST have a wideband installed, hooked up and working. I'd like to keep it as streamlined as possible, and focus on tuning your car and not doing mechanical work to it. If your the first 2.4 or OHV I tune, i'll offer you a discounted price since you'll be the guinea pig and it'll be a learning experience for me in the process.
before altering your car's ecu consider the following:
during modification, some car's ecus get confused and throw CELs. HPT has the ability to disable most of these but not erase them. Therefore a "nullified" ecu will not pass inspection due to "readiness state". please bear this in mind with heavier modified cars that an HPT tune may or may not make them emissions passable. If you don't currently have CELs, HPT will not cause them in anyway. But if you have them already, HPT may not be able to help get rid of them on a completely emissions legal manner.
there's lots of information out there on how to use HPT and set it up and everything, but there still seems to be a lot of confusion. So I offer the following:
"BLIND TUNE"
current requirements:
-wideband and program disc
-96 or newer Jbody
price: $20 per hour
I bring my HPT and laptop, set you up, tune the car and be on my way. you never have to think about it again since the tune will be permanently flashed on your ecu. this may take multiple sessions in order to get just right. tuning is not a concrete setup... some cars are just more difficult than others.
details of a Blind Tune are debatable with owner, but at the least will include the following:
-AFR tune for optimal and consistent fuel curve for zero knock (less than 0.01*kR)
-Spark tuning to maximize power but minimize knock
-fan recalibration
-*reasonable* speed limiter adjustment (based on suspension, tires, condition of car, and engine modifications)
-rpm limiter adjustment (given the state of your valvetrain)
the only downside to a blind tune is if you make any extra physical modification (a new part) the tune cannot compensate.. such is the behavior of an alpha-n ecu.
"J-body HPT 101"
-HPTuners enhanced I/O
-96 or newer Jbody
price: $30 per hour
if you have your own HPTuners, and would like help setting it up and learning to tune I can do that as well for a slightly higher fee.. as well as offering assistance whenever you would need it in the future. think of it as a one-on-one lesson in HPTuners complete with custom histograms and an in-depth how to. This would be a bit more of a lesson on HPT as well as a tune. expect this to last a bit longer than a blind tune.
details of a J-body HPT 101 session are debatable with owner, but at the least will include the following:
-Familiarization with HPT program
-setup of owner's laptop complete with how to make custom histograms
-one-on-one lesson with tuning, and a "cheat sheet" with common changes on j-body ecu and how to make them
-packet on EFI tuning for the J-body written by yours-truly
-fan recalibration
IN THE EVENT OF A MECHANICAL ABORT
a mech. abort refers to a tuning session cut short due to insufficient mechanical parts, failure, or incompatability.
in this event, I will reduce charges to $10 per hour. Seeing as most of these will be apparent within the first hour of the tuning process, if there are any problems, pay me $10 and I'm on my way (since i'll most likely be doing some traveling and I do have to pay for gas.
detals will be hashed out in PMs between myself and the customer.
in the event of damage to vehicle
if a catastrophic failure occurs to the vehicle being tuned during the tuning process, or afterwards I cannot be held accountable. Most problems that were already apparent arise and worsen during the tuning process. please make sure your car is in proper working order before deciding to hire me to tune it for you.
mods, if this is in violation of the rules please delete.
if anyone is interested please feel free to PM me
I would like to tune Jbodies only.. but first timers will get a slight discount in order to compensate for my lack of experience.
ecotec 5 speed owners pay full price seeing as i've tuned mine quite extensively
