01 Chevy Cavalier --- $2000 OBO
2.4L Engine bored .040 over with forged internals (wiseco pistons, eagle connecting rods, arp head studs, Cometic Head Gasket (.074), Port and Polished Head (w/ new SS valves and HO springs and Retainers), "Secret" Cam Swap)
Also has Venom Intake Manifold, RSM 62MM Throttle Body, 660 cc Siemans Injectors and Venom High Flow Fuel Rail. Engine also has oil cooling system and upgraded oil pump.
Transmission is stock other then Team Green LSD installed
Spec Stage 3 Cluctch with Spec 8 lb. Aluminum flywheel also has B&M Shortshifter
Turbo is T3/T4 Turbonetics with Tial 38MM Wastegate and Vortech B.O. Valve
Suspension : Prothane A-arm Bushings, KYB AGX struts, Eibach Sportline Springs, Eibach front and rear sway bars.
Brakes : Have the rear Disc swap from Dodge Neon install
Looking for $2000 OBO, Engine has seen no miles, Transmission was inspected and some internals replaced when LSD was installed no miles since install;
Lots of extra's included at no extra charge...
You can either finish the build or use it as a parts car
i thought show cav was buying it?
LE61T PTE6262 Powered
IS this car put together and in running condition? does it need anything? I am very very interested, but pics and more general info would be lovely.
Hrothgar (zack) wrote:IS this car put together and in running condition? does it need anything? I am very very interested, but pics and more general info would be lovely.
last time i talked to him all it really needs is the charge pipes welded, a boost gauge, wideband and a tune. still for 2000 its a steal considering all the work into the car and the motor and trans have zero miles on it.
i wish I had 2 grand... I'd look past the fact that it's a 2.4 lol
i wanted to buy it but so much time lasped since the last time i talked to him that i ended up buying wheels for the lexus instead
Qwibby {T3H Old QBE} wrote:i wish I had 2 grand... I'd look past the fact that it's a 2.4 lol
Not funny...
Hmm,verrrrrry tempting. My tax return, plus I have charge pipes,boost and wideband gauges, and a flashed 01 pcm lol.
Pics and miore info? Motor is together but just never been driven/broken in?
I have cash in hand, hpt, and a 2 bar map sensor.
dont mean to sound like a n00b but is it running??
it runs but very rough as stated it needs stuff lol. i talked to him about it a while ago cause i wanted to drive it home but it needs towed
yeah thats what i wanted to do, damn! Such a nice car too
yeah...i was going to but decided it wasnt worth the effort to get up and running.
the car is a good buy if someone has the time and money to finish...it does need a paint job too.
hope everything turns out ok.
