LOTS that needs to go..FS all offers and trades considered! - Mid East Region Forum
Saturday, April 24, 2010 2:56 PM
Ok, as most of you know, I have LOTS of stuff I need to get rid of....I am looking for some parts, so I will consider trades. If there is something that the price is too high, make me an offer and we can go from there. Email or PM me if interested. bulllet0597@yahoo.com Thanks!
COMPLETE sunroof assembly, motor, glass, everything - $30
Plastic from around rear windows for 2 door sunfire (Grey) - $10/set
Headliner for car with sunroof - $10
Plastic piece the BCM mounts to - $5
Under seat heat vents (Have 2 sets) - $5/set
Auto shifter assembly - $10
Center console, 97, auto, sanded and painted gloss black to look glassed - $20
Headlight pigtails from 97 cavalier - $5
Cup holder from center console - $5
Plastic piece beside e-brake (Have 2 of them) - $5/each
Heat vent tubing (Have 2 of them) - $5/each
Plastic around trunk latch from sunfire - $5
Plastic around trunk latch from cavalier (Have 2 of them) - $5/each
Sunfire radiator shroud - $10
Cavalier Radiator shroud (From 98) - $10
Plastic in front of the center console (Grey) - $10/set
Small defrost vent tubing - $5
Set of grey 2 door door panels, manual - $20/set
Set of Tan 2 door door panels, manual - $20/set
97 cavalier 2.2, auto gauge cluster - $15
Set of Grey rear seats - $25 GREAT condition
Grey gauge/radio bezel from 97 cavalier, good for a fiberglass project, cig lighter shaved, needs work - $5
Grey driver's side pillar plastic, partially sanded - $5
Grey passenger side pillar plastic - $5
Plastic behind rear seats that attaches to the side panels (Have 3 sets, grey) - $5/set
Carpet retainer plastic (Goes around hood latch, ect.) (Grey) - $10/set
Tan glove box door - $5
Pressure switch for air ride (115/145 PSI switch) - $10
Brake pedal cover for auto - $5
Antenna - $5
Set of 6X9 boxes - $15/set
Sunfire tilt wheel steering column - $10
Sunbird TURBO Throttle body with boost bypass valve - $20
Sunbird TURBO engine wiring harness, complete - $50
Sunbird TURBO fuel pump - $20
Sunbird TURBO fuel injectors - $30/set
Passenger side dash end cap (Grey) - $5
Dash pad wrapped in black tweed - $40
Set of infinity 6X9s - $20
Factory 4X9s - $10
Plastic the speakers mount into (Have 3 sets) - $5/set
Rear deck (Tan) (Can wrap in black tweed if you like) - $10
Plastic around rear windows from cavalier 2 door (Tan) - $10/set
MMS Lambo door kit, needs pivot bearings (Quoted $75 by Joe for them) - Make an offer
Passenger side pillar plastic (Origionally tan, painted blue) - $5
Drivers side pillar plasitc (Tan) $5
Carpet retainer plastic, goes around hood latch, ect. (Tan) - $5/set
Set of 98 cavalier headlights - $40
98 cavalier, base front bumper - $20
98 cavalier. base, rear bumper with mounts - $20
ABS pump - $10
Brake master cylinder - $10
Set of stock door hinges - $15/set
Hose from 2.2/2200 SFI that has the "T" fitting in it (Have 2 of them) - $10/each
Radiator - $25
Complete 2200 SFI intakes (Have 3 of them) - $15/each
NEW serpentine belt from 2000 2200 SFI with A/C - $5
Spare tire (Have 2) - $10/each
2000+ Plastic fuel tank - $30
Surge tank (Radiator reserve tank) - $20
A few small brake lines (Go from ABS pump to master cylinder) - $5/all
Radiator fan (Have 2) - $10/each
Starter from 2200 SFI (2000) - $10
ICM from 2200 - $10
2200 exhaust manifold - $10
2200 plug wires set (Have 2) - $10/each
Upper engine mount from 2200 - $10
Auto trans from 2000 sunfire, 2200 - $50 with torque converter (NEED THIS OUT OF THE WAY!) 142,XXX miles
2200 SFI engine, complete, good running, 142, XXX miles - $250
Passenger side mirror - $10
Drivers side mirror - $10
Set of mirror sails for manual mirrors (Have 3 sets) (Grey) - $10/set
Lines from radiator to trans (2000 sunfire, 2200) - $10
Stock shock.springs - $40/full set
Interior wiring harness from 2000 sunfire with monsoon sound system - $25
Sunfire HVAC assembly with A/C and rear defrost - $15
Armrest for center console from 97 cavalier, grey - $15
Armrest for center console from 97 cavalier, vynal taken off, smoothed and primed, can be painted any color you want - $10 just primed or $50 painted
White streetglow interior strobe - $10
Grey plastic from around steering column, non-tilt wheel - $5
Set of cavalier taillights (2 sets) - $25/each set
Set of black out cavalier taillights (Tinted with VHT nightshades and cleared) - $50/set
Set of plastic around steering wheel, with tilt wheel (grey) - $5
Set of blue vents - $5
PCM from 2000 sunfire, 2200, auto - $25
PCM from 97 cavalier, 2.2, auto - $20
PCM from 97 cavalier, 2.2, auto, TUNED - $35
APC hood pins (Slide style) - $20/each set, new in package
Plastic around child tie down hooks in rear deck - $5/set
HVAC faceplate - $5
Set of grey vents (center ones in gauge/radio bezel) - $5
2000 sunfire headlight bulbs - $5/all
Carbon fiber battle switches - $8/each
25 feet of 2AWG PURE COPPER wire, never used, originally paid over $80 for it - $50
RCA cables (Have 2 sets) - $5/each set
2 Smaller pieces of 0 AWG wire, good for the BIG 3 - $20
LOTS of 4 gauge wire...around 30 foot all together - $25
Piece of 2 AWG wire about 4-5 feet long with ring terminal - $15
4 audiobahn distribution blocks, 1 4AWG in, 2 8 AWG out - $10/each
2.2 OHV vacume line assembly that plugs into TB - $5
Smaller grey vent - $5
ABS computer - $10
Ashtray cup in center console - $5
1 bar MAP sensor - $10
Under hood fuse box cover - $10
Monsoon factory amplifier - $15
Sunfire taillights - $25/set
Set of blacked out outer tails from sunfire - $40
Sunroof switch from 97 cavalier - $5
Power locks switches from 2000 - $10/set
Auto shift knob from 97 cavalier - $10
Terminal plate for speaker wire - $5, gold plated terminals
Sunbird TURBO oil cap - $5
2000 Sunfire owners manual - $10
Sunfire rear bumper cover - $20 (red)
99 GTP PCM , 3800 supercharged - $35
2200 SFI flexplate - $10
Cable from auto shifter to column - $5
Side markers from 98 cavalier - $15
Set of tan sun visors - $15/set
Fuel pump from 2000 sunfire with sending unit and all - $40
Aftermarket radio harness for 97 cavalier - $5
Ring around auto shifter from 2000 sunfire - $5
Hood from 98 cavalier - $40
Dimmer wiring harness with cigarette lighter plug, ect. - $10
Windshield banner from suicide doors "Drag That @!#$" - $10 shipped
Set of CLEAR cavalier taillights, extremely rare - $60/set
ECO valve cover, fully build - Make offer
Carbon fiber overlays, have lots of them left, prices reduced!
Carbon Fiber HVAC - $25 OBO
Carbon Fiber Defrost Vents - $20/set OBO
Carbon Fiber Outer B-Pillars - $55 OBO
Carbon Fiber Passenger Side Air Bag Cover - $55 OBO
Carbon Fiber Dimmer - $25 OBO
Carbon Fiber Dimmer/Fog - $25 OBO
Carbon Fiber Door Inserts (This is the piece that stays on the door when you remove the door panel) - $45 OBO/set
Carbon Fiber Hood Release Handle - $25 OBO
Carbon Fiber Glove Box Handle - $25 OBO
Carbon Fiber Fuel Door - $35 OBO
Carbon Fiber Fuse Door - $35 OBO
Can also accept Custom orders for overlays, just let me know! Thanks.
I also do custom fiberglass, work with tweed, sanding/painting dash pieces for the fiberglass look, and lots of other stuff, get ahold of me with what ya need and I will let you know. HELP ME GET RID OF SOME STUFF! lol
"Hondas are like tampons, every pussy has one!!!"
Re: LOTS that needs to go..FS all offers and trades considered!
Saturday, April 24, 2010 2:58 PM
Also, forgot again have
Glowshift tinted 7 color changing tach - $20
MSD tach adaptor - $15
Green 12" streetglow interior neon - $10
Audiobahn speaker rings from 1206/1208 Qs - $10/set
Audiobahn cone emblems from above subs - $5 - 3 of them
Saturday, April 24, 2010 3:09 PM
dude id like to have the glassed center console if you can pm me with a pic also where ya located man?
Saturday, April 24, 2010 3:12 PM
sorry just reread i sent you a pm.
Sunday, April 25, 2010 5:33 PM
pics of sunroof and color changing tach.
Sunday, April 25, 2010 8:08 PM
pics?
Sunday, April 25, 2010 8:22 PM
ICM from 2200 - $10
Does it include the pigtails?
Monday, April 26, 2010 7:32 AM
You have a pm
Monday, April 26, 2010 1:47 PM
how much for a c/f dash top? centerconsole?
http://www.cardomain.com/ride/3364129
Monday, April 26, 2010 2:06 PM
you still got the gas door?? carbon one
Monday, April 26, 2010 3:53 PM
To those wanting pics, I am working on getting them for you.
ICM does not come with the pigtails
C/F dash top?I do not have a dash top in C/F, sorry
Yes, I still have the gas door.
Monday, April 26, 2010 5:23 PM
I have pics....guys PM me with your emails or post them here and I will send them your way, thanks!
Monday, April 26, 2010 5:51 PM
^^ thats waht i was reffering to.
Monday, April 26, 2010 5:54 PM
Oh, ok. You have been PMd
Monday, April 26, 2010 6:54 PM
hey can you PM me pics of all of your carbon fibre pieces?
Monday, April 26, 2010 7:03 PM
PMd
Monday, April 26, 2010 8:14 PM
MRThompson (jrthompson) wrote:pics of sunroof and color changing tach.
freindlyone99@yahoo.com. i would like to know what all is included for the sunroof to.
Monday, April 26, 2010 8:33 PM
Email with pics sent
Tuesday, April 27, 2010 3:41 PM
pics of carbon fiber overlays please
Wednesday, April 28, 2010 2:21 PM
Email address to send the pics to?
Wednesday, April 28, 2010 7:36 PM
Its in his profile David.
Are those 2200 intakes stock ones?
Edited 1 time(s). Last edited Wednesday, April 28, 2010 7:40 PM
Monday, May 03, 2010 3:05 AM
BUMP! Come on, need stuff gone!
Saturday, May 08, 2010 11:54 AM
BUMP
Saturday, May 08, 2010 8:57 PM
TheSundownFire (GME Chat) wrote:Are those 2200 intakes stock ones?
Edited 1 time(s). Last edited Saturday, May 08, 2010 8:57 PM
Sunday, May 09, 2010 3:06 AM
Sorry Brian, didnt notice that lol, yes, they are stocks
