I have a 2.4 block with the hard part of the oil pump swap done, GM reground crank with 2.3 drive gear installed, pickup, windage tray, brace, Miller oil pan, and 4000 mile pump that i no longer have a use for. The block still needs a few holes drilled and tapped for the windage tray/brace, and would most likely need an over bore. The crank and pump were both installed new at the same time in the last engine i had them in.
I will not ship these items and want to sell as a set. I am open to offers but am looking to get $350 for all of it.
what part of MI are you in... i'd need to map quest it and see if im even able to make that kinda drive... i could definitely use the entire setup... but i guess it depends on whether its less than 15 hours each way, if i could switch days off at work, and if i can get a second driver.
I live in Warren, right next to that @!#$hole called Detroit. I can try to get you some pictures this weekend if you would like. Still dont know where my damn camera is but I have a few places left to look.
well before i read this, i map quested the city where you shipped the Cams from... (the name has now escaped me a couple hours later)...
shows about 12.5 hours w/ tolls or 14 hrs w/out tolls... how far are you willing to travel (i'll go the whole way if i have to, but every little bit less of the trip matters)...
i'll pm you when i get off work with a couple more questions, but if all goes well hopefully next weekend i can roll out there
EDIT: PM SENT!!!
Edited 2 time(s). Last edited Thursday, August 13, 2009 5:40 PM
Clyde: Havent heard from ya in a couple days... is everything still good?
JBO Chat User: Speedline02 wrote:Clyde: Havent heard from ya in a couple days... is everything still good?
I had one busy ass weekend. I replied.
