I am ditching my 2.4 for a 3400 so I am selling off some stuff. all that is for sale is whats listed so please dont ask if i have XX from my car for sale if its not listed ive already sold it or am re-using it!
Engine & engine stuff
-exploited racing stainless log manifold w/ext wastegate flange, flange to head re machined flat. EC $200
-good (used) relatively high mileage but strong running 2.4 $300
-junkyard charge pipes 2" hot 2.5" cold look like ASS but will allow you to run pipes UNDER THE CAR even with an automatic (what i had) everything you need incl cheap plastic BOV from saab will fit 2.5" - 3" inlet / outlet on a FMIC $100
COMPLETE 5 speed swap comes with the following for $700 (will NOT part)
-2.4 isuzu trans w/ 2.2 gears
-good used stock axles & cv's
-B&M short shifter for isuzu
-used flywheel w/ used act 6 puck unsprung clutch & hd pressure plate
-clutch pedal assy & clutch master cyl
-shift cables
-poly trans mount inserts (with trans mounts)
-97 & 99 5 speed pcm's
FREE stuff if you come to buy any of the other stuff
-stock harness
-used alts starters interior and exterior parts (unspecified)
-random hardware, ac parts (all of it for 2 cars)
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
