have all my paintball gear up for sale. heres the pics and info.
first off dye mask comes with the box, the carrying bag and mask lenses are not included they were cracked in the last tournament you should always buy new lenses anyway after a bit of use. your eyes are worth it.
freak barrle system to match your paint to your gun. also have a list of sizes for most paint on the market so you can adjust your barrel to work with the paint, its a great barrel system and i loved it. over 20 cases of paint shot thru it with only 1 broken ball.
harness pack, holds 6 120 or 140 round tubes. i have probalby 8-10 tubes to go along with it.
egg loader. think it holds just over 200 paintballs. i do believe the battery cover broke but some tape will fix that or you can problaby pick up a new cover from a paintball store that sells them.
nitro tank i believe it its a 65cu 4500 psi tank. its all packed away right now but if people are intrested i will pull it out to make sure. comes with a dye neoprene cover.
have a case and a half or so of paint, its old but good practice stuff and my gun should shoot it fine. i shot two year old paint thru it with out any issues.
and heres the gun its an autococker that ive replaced just about everything on it. all it would need would be an eblade to compete at the highest tournament level.
all the valving has been replaced. it has dye grips. its had a trigger job done to it. lightened block eclipse ball dent, 32 degree flamed drop. the bomb 3-way mini adjustable rock regulater. pressure gauge built into the underside of the block, i have a new aka valve for it but not installed to get the pressure down low. i bought the gun pretty much stock reworked it over with all the parts and then played a few tournaments with it. couple guys moved away and with the car and kid i just didnt have the time devoted to stay in the tournament level of play so im letting it go.
i also have most of the stock parts as well.
also have dye pants that fit me. im 6-4 200lbs. only worn twice (i generally play in shorts and only 2 tournaments made me wear pants)
im looking for $400or best offer the gun is in great shape and as said above ive shot over 20 cases thru it with only 1 broken ball. someone make me an offer and get this out of my closet.
how much for the gun?
__________________--------------------------____________________
Team: NONE RIGHT NOW
Sponsored By: Pro Trucks
Work Being Done By: creative customs
Stuff for Sell:
How much for just the tank and maybe the pants....or just the tank, I'm on the fecne about the pants, but I def. am interested in the tank.
My friend has been looking for a new used cocker for a while I let you know.
How much for everything???
2004 Turbo cavalier 11PSI and blown!
His origional post says $400 obo
Cool man, just hit me with a pm, as I'll probably forget to check this thread.
damn, that's one hell of a deal....If I needed a gun I'd be all over it.
