Ok first want to say I am going to be in indy this fri. and sat.(dec. 9th and 10th) and could bring any of parts listed with me to indy.
Prices do NOT include shipping cost
17x8" 35mm offset 5 zigen fn01rc in hyper black( you can no longer get this color) 225/45/17 falken 615. These wheels are ocd clean with only one blemish on 1 lip(see picture) 2 tires are brand new with the azenis still in them, and the other 2 are about 30%. $800
rksport type j side skirts $50 start of a fiberglassed dash $20
2 1/16" autometer cobalt series electronic oil pressure gauge with wiring $100
golden eagle vacuum block $25
polished alum coolant tank with cap $30
gunmetal and black center consol $75
black a-pillars with a single guage pod $30
2.4 black timing chain housing $25
2.4 timing chain cover blue or chrome silver $20
2.4 timing chain housing $15
00 gauge cluster with cf insert $75
2.4 idi covers $10 a piece
2.3 timing chain housing and cover $30
cloyes 2.3 double roller timing chain set with guides $50
cavalier charcoal with red dot seats front and rear $50
00 cavalier charcoal with red dot door panels, driver side is worn on top near the window $15
2.4 turbo header,brand new ready to have a external wastegate welded on $650
2.4 side winder setup, header uses a t3 flange and tial 44mm wastgate. to be able to use this you will have to swap to manual brakes and most likely have to move the location on the fire wall. Or you can cut the pipe and change the location of the turbo placement to be able to possilbly retain factory brakes.
header, dump tube, and downpipe $750 header and dp are black ceramic coated
3.5" alum exhaust with vibrant street power muffer $400 Cant be used with a factory tank in place.
GT3582r t3 w/3" vband outlet .82ar, black ceramic coated exhaust housing, blue painted anti surge compressor housing. comes with -6 water line fittings $850
Tial 44mm wastegate, black ceramic coated housing with a polished top $225
Ecotec header not finished just tac'd together for a manual car only $350
custom dual pass radiator with -16an inlet/outlet -12an coolant tank feed line, 2 -6an overflow bungs, selling with coolant tank that goes in the cowl, -12 line from tank to rad. -16an water neck powdercoated black, -16 line from waterneck to rad. $550
00-02 cavalier headlight right side $10
95+ cavalier mirror right side, silver in color $10
Brand new cavalier front half fender liners $ 20ea. or $35 for the 2
2.4 oem rad. with cooling fan $20
2.4 alternator with aem under drive pulley $25
Aem under drive alternator pulley $10
Coolant tank with rksport cf cover $40
2.4 oem throttle body $10
2.4 00 ecu $20
2.4 crank pulley oem $5
2.2 ohv powersteering pump $15
2.4 coil pack $10
alpine cd player cda-9853, like new $125
00+ toyo fenders with the light holes shaved, gunmetal in color $250
00-02 z24 front bumper with wings west w lip, gunmetal in color, unable to use fog lights because was cut for charge pipes $150
95-02 sunfire aerogear millennium body kit with fender flares. $300
http://www.bodykits.com/Aerogear/Body-Kits/Pontiac-Sunfire-Aerogear-Millennium-Series-Full-Body-Kit-With-Front-and-Rear-Fenders-_-AG_2105_BK/632129/
rksport lower mount $15 stock 2.4 fuel rail with -8an fittings welded on $25
2.4 .5" alum head flange $70
2.4 .5"thick mild steel head flange $50 t4 mild steel flange $15
shl. 10 1.5" 304 ss 4-1 collector with t3 flange. $35
Buy my stuff!!! CLICK
R.I.P. Brian Klocke, you will never be forgotten
